1. Re: Temporarily "downgrading" CF10 Standard to Developer
Aegis Kleais Apr 4, 2013 4:56 PM (in response to Aegis Kleais)If no one is familiar with how to do this, does anyone know how I can backup the server's configurations via export so when I uninstall CF and install the Developer version in its stead (and then fix the issue), I can re-enter the license key and then re-import all the settings?
2. Re: Temporarily "downgrading" CF10 Standard to Developer
Anit Kumar Panda Apr 4, 2013 5:15 PM (in response to Aegis Kleais)Hi,
To backup the settings, you can use the ColdFusion Archives feature. Please visit http://blogs.coldfusion.com/post.cfm/a-new-video-on-coldfusion-10-archives-is-posted-on-yo utube-channel.
Regards,
Anit Kumar
3. Re: Temporarily "downgrading" CF10 Standard to Developer
Adam Cameron. Apr 4, 2013 5:17 PM (in response to Aegis Kleais)The licence number is in cfusion/lib/license.properties (I googled that, btw), and if you take the licence number out of that and restart, you'll be back on the dev edition.
Adam
4. Re: Temporarily "downgrading" CF10 Standard to Developer
Adam Cameron. Apr 4, 2013 5:19 PM (in response to Anit Kumar Panda)Although you can't do that on a standard licence, Anit, which is what Aegis is actually trying to work around.
Adam
5. Re: Temporarily "downgrading" CF10 Standard to Developer
Anit Kumar Panda Apr 4, 2013 5:28 PM (in response to Adam Cameron.)Yes, I should have mentioned this.
Aegis Kleais You will have to first follow Adam's step and then the one suggested by me. Please correct me Adam, if i am wrong.
Regards,
Anit Kumar
6. Re: Temporarily "downgrading" CF10 Standard to Developer
Adam Cameron. Apr 4, 2013 5:32 PM (in response to Anit Kumar Panda)Hi Anit: all good, that's spot on.
Adam
7. Re: Temporarily "downgrading" CF10 Standard to Developer
Aegis Kleais Apr 5, 2013 7:02 AM (in response to Adam Cameron.)Looks like it worked. Removing the SN and starting up the server has it running in developer mode. Hopefully now there will be no snafus with it seeing 2 servers running off the same SN while I get whatever the heck is wrong with this server fixed. That saves me a lot more time than doing backups and re-installations. Thanks guys!
