1 Reply Latest reply on Apr 4, 2013 10:35 AM by Genevieve Laroche
    Form created but saved as pdf.
    ipm Level 1
      I originally created a form using forms central, saved it as a pdf to test knowing I needed to go back and correct typos etc.  Unfortunately it is no longer in the forms central section!  I tried importing it but get the message that it has already been distributed.  It wouldn't be that big of a deal but it's a 7 page long form with multiple questions-lots of entry!  Please help.
      This is my 2 form I created so I learned a valuable lesson. Thank you in advance for anyone's help.
        • 1. Re: Form created but saved as pdf.
          Genevieve Laroche Adobe Employee
          Are you saying that you deleted the original form in FormsCentral? Were you the author of that original FormsCentral form?
          You can't import a FormsCentral PDF form back into FormsCentral. You wouldn't be able to fix any typo anyway since it would be an imported PDF and not a be a form designed in FormsCentral anymore.
          If the issue is only a few typo in the static text then you can make the changes directly in Acrobat.
