0 Replies Latest reply on Apr 4, 2013 1:46 PM by camohr
    CFLDAP: can't bind to AD as "currently logged on user"
    camohr
      First I used Softerra's LDAP browser to figure out what I need to gain access to our AD.
      Specifically I had to use this bind technique:
      CFLDAP attempt leaving out username:
      <CFLDAP
        action="query"
        name="results"
        start="CN=js9999,OU=XXXXX,OU=Users,OU=xxxxx,DC=XXXXXX,DC=xxx,DC=com" attributes="*"
        server="ouradserver.bigcorp.com"
      RESULT: An error has occured while trying to execute query :[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906DD, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1772 ].
      Attempt with username and no password.
      <CFLDAP
        action="query"
        name="results"
        username="js9999"
      RESULT: The system has attempted to use an undefined value, which usually indicates a programming error, either in your code or some system code. Null Pointers are another name for undefined values.
      It insists on a password, which I do NOT want to provide.
      Attempt with "rebind" parameter:
      <CFLDAP
        action="query"
        name="results"
        rebind="yes"
      RESULT: An error has occured while trying to execute query :[LDAP: error code 1 - 000004DC: LdapErr: DSID-0C0906E8, comment: In order to perform this operation a successful bind must be completed on the connection., data 0, v1db1 ].
      Does CFLDAP support this scenario? (bind using provably-authenticated current user)
      ColdFusion 9 is running under IIS 7 on a Windows 2008 server.
