2 Replies Latest reply on Apr 6, 2013 12:20 PM by The King of Milk2
    Trying to do an 'if' function need help
    The King of Milk2
      I have four values that I want to input into a field. What I am trying to make happen is when you type in a letter, that text field will then highlight or fill to a certain color. Can anyone help me? And I want to have four values in it. The values would be "G" "R" "Y" and "0". If I type in "G" I woud like the field to fill/highlight green. I am not good at scripting. any help would be amazing.
        • 1. Re: Trying to do an 'if' function need help
          Mandy_Wiesener Level 3
          I'm not sure if I understand you right.
          Here is a script that check if you leave the field which entry the user makes.
          If the entry is a "G" the field will be filled with color.
          You have to use this script in the change-event of the script editor. This allows to entry only G or R or Y or 0.
          if(xfa.event.newText.match(/[^GRY0]/))
           xfa.event.change = "";
          And this script you have to use in the exit-event of the script editor. This checks if your entry is a "G".
          if(this.rawValue == "G")
              Textfeld1.fillColor = "245,245,0";
          }else
              Textfeld1.fillColor = "255,255,255";
          The script editor you will find about "window".
          Hope it will helps you,
          Mandy
          • 2. Re: Trying to do an 'if' function need help
            The King of Milk2 Level 1
            It was helpful and got it working. I'm trying to mess with it right now. But with that script it only makes it green. I tied typing in r or y and it comes up white or no fill. But I'm trying to tinker with it. I appreciate it so much Mandy!!!
