6 Replies Latest reply on Aug 17, 2016 12:53 AM by o-marat
    Save Only The Artboard area into AI file
    Harsh V Sharma
      Is it possible to save only the ARTBoard Area into a new AI document by using JSX.
      for example in the above image I want only the yellow marked drawing ,that is inside the artboard area, to be save in the new document [AI file] by using JSX.
        • 1. Re: Save Only The Artboard area into AI file
          zertle Level 2
          Would it be alright to use a clipping mask to hide everything outside of the artboard?  That shouldn't be too crazy of a script.
          • 4. Re: Save Only The Artboard area into AI file
            o-marat Level 3
            [CS6+] Suboptimal and  maybe strange, but it seems to work well:
            • Support only one artbord.
            • Crop PageItems (PathItems) on active layer.
            • Tested by little, then so be careful.
              Created under the inspiration of the Silly-V's script
             * ai.jsx (c)MaratShagiev m_js@bk.ru 17.08.2016
            //@target illustrator-20
            (function cropToArtb () {
              setZero ();
              clearOutOfArtb ();
              expandAll ();
              ungroupAll (activeDocument.activeLayer);
              cropAllToArtbRect (activeDocument.activeLayer);
             function clearOutOfArtb () {
                executeMenuCommand ('selectallinartboard');
                executeMenuCommand ('Inverse menu item');
                executeMenuCommand ('clear');
              function expandAll () {
                executeMenuCommand ('selectall');
                executeMenuCommand ('expandStyle');
                executeMenuCommand ('deselectall');
              function ungroupAll (lay) {
                while (lay.groupItems.length) {
                  executeMenuCommand ('ungroup');
              function cropAllToArtbRect (lay) {
                try {
                  _actAdd_intersect ();
                  for (var i = lay.pageItems.length - 1; i >= 0; i--) {
                    var item = lay.pageItems[i];
                    if (!_outArtbTest (item)) continue;
                    var cropRect = _makeCropRect (lay);
                    cropRect.move (item, ElementPlacement.PLACEAFTER);
                    item.selected     = true;
                    cropRect.selected = true;
                    app.doScript ("intersect", "intersect", false); // action name, set name
                } catch (e) {
                } finally {
                  try {
                    app.unloadAction ("intersect", ""); // set name
                  } catch (e) {
            // if the item is out from artb then  @return {true}
                function _outArtbTest (item) {
                  var d          = activeDocument;
                  var artbIndex  = d.artboards.getActiveArtboardIndex ();
                  var artbRect   = d.artboards[artbIndex].artboardRect;
                  var itemBounds = item.geometricBounds; // left top right bottom
                  return itemBounds[0] < artbRect[0] || itemBounds[1] > artbRect[1] ||
                    itemBounds[2] > artbRect[2] || -itemBounds[3] > -artbRect[3];
                function _makeCropRect (lay) {
                  // top left width height
                  var cropRect  = lay.pathItems.rectangle (artbRect[1], artbRect[0], artbRect[2], -artbRect[3]);
                  return cropRect;
                function _actAdd_intersect () {
                    var actStr = '' +
                      '/version 3' +
                      '/name [ 9' +
                      ' 696e74657273656374' +
                      '/isOpen 0' +
                      '/actionCount 1' +
                      '/action-1 {' +
                      ' /name [ 9' +
                      ' /keyIndex 0' +
                      ' /colorIndex 0' +
                      ' /isOpen 0' +
                      ' /eventCount 2' +
                      ' /event-1 {' +
                      ' /useRulersIn1stQuadrant 0' +
                      ' /internalName (ai_compound_shape)' +
                      ' /localizedName [ 14' +
                      ' 436f6d706f756e64205368617065' +
                      ' /isOpen 0' +
                      ' /isOn 1' +
                      ' /hasDialog 0' +
                      ' /parameterCount 2' +
                      ' /parameter-1 {' +
                      ' /key 1851878757' +
                      ' /showInPalette -1' +
                      ' /type (enumerated)' +
                      ' /name [ 9' +
                      ' 496e74657273656374' +
                      ' /value 1' +
                      ' /parameter-2 {' +
                      ' /key 1836016741' +
                      ' /type (integer)' +
                      ' /value 0' +
                      ' /event-2 {' +
                      ' /internalName (ai_expand_compound_shape)' +
                      ' /localizedName [ 21' +
                      ' 457870616e6420436f6d706f756e64205368617065' +
                      ' /isOpen 0' +
                      ' /isOn 1' +
                      ' /hasDialog 0' +
                      ' /parameterCount 1' +
                      ' /parameter-1 {' +
                      ' /key 2020634212' +
                      ' /value 0' +
                  var f = new File ('~/ScriptAction.aia');
                  f.open ('w');
                  f.write (actStr);
                  f.close ();
                  app.loadAction (f);
                  f.remove ();
              // Set Zero point ruler on Document an artboard
              function setZero () {
                var i                      = d.artboards.getActiveArtboardIndex ();
                d.rulerOrigin              = [0, d.height];
                d.artboards[i].rulerOrigin = [0, 0];
            • 5. Re: Save Only The Artboard area into AI file
              Silly-V Adobe Community Professional
              Just noticed, this question was from 3 years ago? lol
              • 6. Re: Save Only The Artboard area into AI file
                o-marat Level 3
                Oh! I'm overlooked the date of item   ha-ha
                As the saying goes: Better late than never...If your question is not answered in several years – don't lose hope!.. and so on... )))
