2 Replies Latest reply on Nov 17, 2013 3:44 PM by Dina Hess
    Return Soap Fault in CF web service
    Dina Hess
      How do I return a Soap Fault like this:
               <faultstring>SalesCode must be 5 characters in length</faultstring>
      instead of a CFCInvocationException?
        • 1. Re: Return Soap Fault in CF web service
          raZorTTZ Level 1
          Hi Dina,
          Did you find a solution to your problem? I'm looking at doing the same thing.
          • 2. Re: Return Soap Fault in CF web service
            Dina Hess Level 1
            I had to use a workaround. In the complex type (CFC) returned by the web
            service, I added two additional properties, success (boolean) and fault
            (string). That way, if validation fails, I set success to false and return
            validation messages in the fault property using syntax like this:
            . It communicates what the client needs to know but
            is not in the format I originally wanted to implement. I did find a clue
            about how to get control of the SOAP envelope in a comment made by Arthur
            Blake at the end of one of Ben Nadel's blog entries about using HTTP to
            consume a web service. He said he could customize the XML request/response by
            writing a "proxy" in ColdFusion that forwards to the real SOAP service. I
            never did figure out how to go about doing that, so if you happen to get
            your head around it, please post your solution. In general, I found that
            ColdFusion 8 doesn't play nicely with a pre-defined complex WSDL that
            import XSDs and doesn't honor a "required=no" setting in the property tag
            of a complex type's CFC when generating its WSDL dynamically. In fact, I
            have a whole list of "gotchas" on this... Didn't mean to write a book, but
            you opened an old wound that had just about healed. Good luck, Simon.  Hope
            I didn't douse too much water on your passion to move forward with this.
