0 Replies Latest reply on Apr 5, 2013 6:59 AM by pinkstonms
    Solution anyone?
    pinkstonms Level 1
      In the Edge display below the white area is an object created in Illustrator and imported into Edge as SVG. It will be duplicated and rotated to make up a complete circle of 50 elements.
      That being said the object(s) will be coded as a button in Edge. Here is the problem, if you look at the rendering below only the white area should be the active area for the button but either as PNG or SVG the entire bounding box area represented in the darker red area is active. So if you look at the one on the right it is off the button but still active due to the bounding box associated with the bitmap or flattened SVG.
      In Flash I would simply import the vector and get what I need BUT I Cannot Figure Out a Workaround for this in EDGE.
