1 Reply Latest reply on Apr 5, 2013 3:57 PM by Rick Gerard
    Expression for offset postion
    preditorj40153117 Level 1
      I have this expression.
      thisComp.layer("Black Solid 3").effect("Particular")("Position XY")
      Its is simplely a lens flare (cc lens flare) following the position of a particle (particular).
      Particular's emmitter type is box and the actual particle lags behind about 20px.
      I do not want to keyframe because of the amount of key points and the speed of movement.
      Can i add something to the pick-whipped expression that would allow me to offset the position to be slightly behing TCpaticulars position?  -- (if that makes sense)
      BTW, is there a better flare than cc particle in TC?
        • 1. Re: Expression for offset postion
          You need to add a value at time method to your expression. This will allow you to add or subtract the value of any property at the current time measured in seconds. For example if I had layer 1 and layer 2 this expression applied to layer 2's position property would make layer 2 follow layer 1 by .5 seconds.
          thisComp.layer("layer 1").position.valueAtTime(time - .5)
          By the way this expression is referenced right in the Expression Language section of the help file. It's on the first page.
