2 Replies Latest reply on Nov 7, 2007 3:01 PM by ihink909
    Navigating to a Frame Label
    ScottE Level 1
      Hi All,
      I am trying to navigate from one mc to another mc and specifically to a frame labe in the targeted mc.
      The code I have does work in terms of getting to the target mc but I can't get it to go to the mc:
      on (release) {
      _root.pages.gotoAndStop(_root.link = 3);
      I tried this to get to the frame label "multi" but all it does it what the above code does:
      on (release) {
      Can anyone help me on a solution for this?
      Many Thanks,
        • 1. Re: Navigating to a Frame Label
          why are you assigning _root.link to be 3 in your goto method? and now that i look at more of your code, i see more screwy things.
          what's the path/name of the movieclip which you want to control and what's the frame label (or variable that contains the label or number) that you want to play.
          • 2. Navigating to a Frame Label
            agree with kglad above, for a button or movie clip, just select it and use a code like mine. this case my frame label is home which you can easily set using script assist if you need to. maybe its mroe complicated than that but i have similar situation and this is how i did it. works great.
