How do I set up a .pdf form to save filled data without having to print the form? I have provided my clients a lifecycle .pdf form they can use to record data for unique client meetings. They want the ability to save their completed data whenever they use the form under a unique file name. I've told them the only way I know how to do this is to print the completed form as a .pdf document and then save it.
Is their a way to save the data to a unique file name without printing the filled form?
Is there a way to reset the form with blank fields after saving? or to add a clear fields button?
Thanks.
If you reader extend a pdf using livecycle reader extensions then you can save the filled in data - this is true if you are using Adobe reader to view the PDF's. If you open it in Acrobat then the functionality is already there.
