3 Replies Latest reply on Apr 8, 2013 9:31 AM by pdxland
    AuthenticationSupport service missing. Cannot authenticate request.
    pdxland
      New Windows 7 machine
      Java JRE7 (32-bit)
      A fresh copy of CQ5-5 from Adobe's site.
      I continually get this error. I have tried it using 64-bit java too. No change.
      One note: if I remove the license file, it does ask me for the key and then lands on this page.
      I was able to use this fine in my old XP machine.
      I see posts about starting services from the Felix console etc. I don't know how, nothing comes up in the browser.
      I have tried deleting index.* files from various directories as mentioned in a few of the posts.
      I have tried uninstalling Java, restarting machine, installing Java, restarting machine and such.
      Absolutely new install, I am slightly baffled by this.
      Below is the quirky messages I see on the command prompt. I've played around with the -Xms arguments, added -XX:MaxPermSize=256M, some warnings go away but end result is the same.
      Any inputs are welcome!
      C:\author> java -Xmx1024M -jar cq5-author-p4502.jar
      Loading quickstart properties: default
      Loading quickstart properties: instance
      Low-memory action set to fork
      Using 64bit VM settings, min.heap=1024MB, min permgen=256MB, default fork arguments=[-Xmx1024m, -XX:MaxPermSize=256m]
      **** WARNING: insufficent heap memory ******************************************
      The JVM reports 910 MB but we recommend at least 1024 MB +/- 20
      Use your JVM's heap size option (like -Xmx1024M) to set that size.
      Will fork a JVM to get enough memory.
      **** WARNING: insufficent PermGen memory ***************************************
      The JVM MBean:PS Perm Gen reports 82 MB but we recommend at least 256 MB +/- 20
      Use your JVM's PermGen size option (like -XX:MaxPermSize=256M) to set that size.
      No console, will fork to get enough memory
      Preparing to fork JVM, OS name=Windows 7, isWindows=true
      Forking JVM: [C:\Program Files\Java\jre7\bin\java.exe, -Xmx1024m, -XX:MaxPermSize=256m, -jar, C:/Users/pdxland/Documents
      /CQ5-5-Author/CQ5-author-p4502.jar, -nofork, -pt, CHILD]
      The JVM MBean:PS Perm Gen reports a maximum size of 256 MB, meets our expectation of 256 MB +/- 20
      Not forking JVM as -nofork option is set
      Setting properties from filename 'C:/Users/pdxland/Documents/CQ5-5-Author/CQ5-author-p4502.jar'
      Property '-quickstart.server.port' set to '4502' from filename CQ5-author-p4502.jar
      Property '-r' set to 'author' from filename CQ5-author-p4502.jar
      Property '-r' is already set (author), ignoring new value (author) derived from filename
      System property 'sling.run.modes' set to 'author' by -r option
      Verbose option not active, closing stdin and redirecting stdout and stderr
      Redirecting stdout to C:\Users\pdxland\Documents\CQ5-5-Author\crx-quickstart\logs\stdout.log
      Redirecting stderr to C:\Users\pdxland\Documents\CQ5-5-Author\crx-quickstart\logs\stderr.log
      Press CTRL-C to shutdown the Quickstart server...
