1 Reply Latest reply on Apr 8, 2013 12:22 PM by George_Johnson
    Show/hide objects/fields in PDF application (form) ...
    gtasick Level 1
      Hello,
      I'm creating a PDF application (form).
      The layout is being done in InDesign then the fields/buttons/drop-down boxes are being added in Acrobat Pro.
      I have a situation in the application where the user will select an option from a drop-down menu ... let's say the options are "car" and "airplane". (These are just examples.)
      when the applicant selects "car" it should only show the following fields ...
      • Tires
      • Engine
      • Fuel Economy
      When the applicant selects "airplane" it should only show the following fields ...
      • Wingspan
      • Max. Altitude
      • Seating Capacity
      How do I do this? I only want the applicant to see/access the fields that are relevant to the selections they make earlier in the application.
      From what I've found online, "Java Script" is what I need to work with ... but I have no idea how that works.
      I have no ability to write code from scratch, but I have been successfull at modifiying existing code.
      Some examples or some code that I can copy/paste and modify would be great.
      Also, where do I go within Acrobat to access/modify the code?
      Thanks in advance!
