3 Replies Latest reply on Apr 8, 2013 4:30 PM by kglad
    Loop movie on a single frame with AS2?
    nicolasp89
      Hi, i'm animating a web banner, which is supposed to loop infinite times. The thing is, i learnt to use tweening prototype for my animation, so the entire code is written on a single frame.
      Is there a way to loop the entire movie at the end?
        • 1. Re: Loop movie on a single frame with AS2?
          put whatever code that initiates your animation into a function body.  call that function when your animation ends.
          • 2. Re: Loop movie on a single frame with AS2?
            nicolasp89 Level 1
            Thanks! but I still need help.
            Ok, let's say this is the code:
            function iniciar (){
            //INTRO//
            _root.fondo._x=2632;
            _root.fondo._y=223;
            _root.fondo.tween("_x",-38,25,"easeOutCubic",0.5)
            _root.bloqueintro._x=535
            _root.bloqueintro._y=226
            _root.bloqueintro.tween("_x",-600,1.5,"easeOutCubic",6.5)
            _root.opt._x=468
            _root.opt._y=-50
            _root.opt.tween("_y",146,1.5,"easeOutCubic",1.5)
            _root.opt.tween("_x",-270,1.5,"easeOutCubic",6.5)
            _root.esp._x=530
            _root.esp._y=198
            _root.esp._yscale=0
            _root.esp.tween("_yscale",100,1,"easeOutBounce",2.5)
            _root.esp.tween("_x",-459,1.5,"easeOutCubic",6.5)
            _root.de._x=621
            _root.de._y=246
            _root.de._yscale=0
            _root.de.tween("_yscale",100,1,"easeOutBounce",2.5)
            _root.de.tween("_x",-368,1.5,"easeOutCubic",6.5)
            _root.trab._x=664
            _root.trab._y=292
            _root.trab._yscale=0
            _root.trab.tween("_yscale",100,1,"easeOutBounce",2.5)
            _root.trab.tween("_x",-325,1.5,"easeOutCubic",6.5)
            //CONECTOR//
            _root.conector._x=1659;
            _root.conector._y = 244;
            _root.conector.tween("_x",-800,1.5,"easeOutCubic",6.5);
            _root.conector2._x=-800;
            _root.conector2._y = 244;
            _root.conector2.tween("_x",1924,1.5,"easeOutCubic",13);
            _root.conector3._x=1924;
            _root.conector3._y = 244;
            _root.conector3.tween("_x",-800,1.5,"easeOutCubic",21);
            _root.conector4._x=-800;
            _root.conector4._y = 244;
            _root.conector4.tween("_x",1924,1.5,"easeOutCubic",27);
            iniciar();
            So the whole animation is now into a function body. Still, how can i loop that function, if i only have one frame?
            • 3. Re: Loop movie on a single frame with AS2?
              use:
              clearInterval(iniciarI);
              var iniciarI:Number=setInterval(iniciar,2000);
              iniciar();
              //INTRO//
              _root.fondo._y=223;
              _root.opt._x=468
              _root.opt._y=-50
              _root.esp._x=530
              _root.esp._y=198
              _root.esp._yscale=0
              _root.de._x=621
              _root.de._y=246
              _root.de._yscale=0
              _root.trab._x=664
              _root.trab._y=292
              //CONECTOR//
