3 Replies Latest reply on Apr 14, 2013 8:15 PM by Sham HC
    permissions
    codonvirginia
      I try to move the user and group from old server to new sever by create the user and group package. The user and group can move to new server but
      the users dont have the same permission in old server. anyone have done this , can you give me the step by step  or do you know why I got this problem.
      Thank you very much.
      Jenny
        • 2. Re: permissions
          codonvirginia Level 1
          Hi Yogoesh,
          I got thi exeption whent I do by this way "<host>:<port>/apps/tools/components/createPackage/run.html"
          No resource found
          Cannot serve request to /apps/tools/components/createPackage/run.html in /libs/sling/servlet/errorhandler/404.jsp
          Request Progress:
                0 (2013-04-09 09:07:18) TIMER_START{Request Processing} 0 (2013-04-09 09:07:18) COMMENT timer_end format is {<elapsed msec>,<timer name>} <optional message> 0 (2013-04-09 09:07:18) LOG Method=GET, PathInfo=/apps/tools/components/createPackage/run.html 0 (2013-04-09 09:07:18) TIMER_START{ResourceResolution} 0 (2013-04-09 09:07:18) TIMER_END{0,ResourceResolution} URI=/apps/tools/components/createPackage/run.html resolves to Resource=NonExistingResource, path=/apps/tools/components/createPackage/run.html 0 (2013-04-09 09:07:18) LOG Resource Path Info: SlingRequestPathInfo: path='/apps/tools/components/createPackage/run.html', selectorString='null', extension='html', suffix='null' 0 (2013-04-09 09:07:18) TIMER_START{ServletResolution} 0 (2013-04-09 09:07:18) TIMER_START{resolveServlet(NonExistingResource, path=/apps/tools/components/createPackage/run.html)} 1 (2013-04-09 09:07:18) LOG {0}: no servlet found 1 (2013-04-09 09:07:18) TIMER_END{1,resolveServlet(NonExistingResource, path=/apps/tools/components/createPackage/run.html)} Using servlet org.apache.sling.servlets.get.DefaultGetServlet 1 (2013-04-09 09:07:18) TIMER_END{1,ServletResolution} URI=/apps/tools/components/createPackage/run.html handled by Servlet=org.apache.sling.servlets.get.DefaultGetServlet 1 (2013-04-09 09:07:18) LOG Applying Requestfilters 1 (2013-04-09 09:07:18) LOG Calling filter: org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter 1 (2013-04-09 09:07:18) LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter 1 (2013-04-09 09:07:18) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter 1 (2013-04-09 09:07:18) LOG Calling filter: com.day.cq.wcm.core.impl.WCMRequestFilter 1 (2013-04-09 09:07:18) LOG Calling filter: com.day.cq.theme.impl.ThemeResolverFilter 1 (2013-04-09 09:07:18) LOG Calling filter: com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet 1 (2013-04-09 09:07:18) LOG Calling filter: org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter 1 (2013-04-09 09:07:18) LOG Calling filter: com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter 1 (2013-04-09 09:07:18) LOG RedirectFilter did not redirect (request path does not match) 1 (2013-04-09 09:07:18) LOG Calling filter: com.day.cq.wcm.core.impl.warp.TimeWarpFilter 1 (2013-04-09 09:07:18) LOG Applying Componentfilters 1 (2013-04-09 09:07:18) LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter 1 (2013-04-09 09:07:18) LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter 1 (2013-04-09 09:07:18) TIMER_START{org.apache.sling.servlets.get.DefaultGetServlet#0} 1 (2013-04-09 09:07:18) TIMER_END{0,org.apache.sling.servlets.get.DefaultGetServlet#0} 1 (2013-04-09 09:07:18) LOG Applying Error filters 1 (2013-04-09 09:07:18) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter 1 (2013-04-09 09:07:18) TIMER_START{handleError:status=404} 33 (2013-04-09 09:07:18) TIMER_END{32,handleError:status=404} Using handler /libs/sling/servlet/errorhandler/404.jsp 34 (2013-04-09 09:07:18) LOG Found processor for post processing ProcessorConfiguration: {contentTypes=[text/html],order=-1, active=true, valid=true, processErrorResponse=true, pipeline=(generator=Config(type=htmlparser, config={}), transformers=(Config(type=linkchecker, config={}), Config(type=mobile, config=org.apache.sling.jcr.resource.JcrPropertyMap@781d929f), Config(type=mobiledebug, config=org.apache.sling.jcr.resource.JcrPropertyMap@5d854254), Config(type=contentsync, config=org.apache.sling.jcr.resource.JcrPropertyMap@57c5c8c3), serializer=Config(type=htmlwriter, config={}))} 34 (2013-04-09 09:07:18) TIMER_END{34,Request Processing} Dumping SlingRequestProgressTracker Entries
          Can I do by other way by click on Package in CQ5 then click on create package then click on edit , then add filter then build then download.
          I have done that way before but when in move to new sever I can not login the user I copy from old sever to new sever.
          I think the permission problem.
          Can you help me.
          Jenny
          • 3. Re: permissions
            Sham HC Level 7
            Hi Jenny,
            As a first step you need to install the package yogesh has provided in his blog. Once you install you can access using <host>:<port>/apps/tools/components/createPackage/run.html
            Sham
