1 Reply Latest reply on Apr 9, 2013 5:07 AM by JJMack
    Can't convert timeline to frame animation
    Schennae
      Whenever I try to upload a video clip, it only shows in timeline format and when I try to convert it to frame animation, it says "The video will not play back in frame animation." Help, please
        • 1. Re: Can't convert timeline to frame animation
          I do not do video but have an idea if the video segments you want to make a frame animation is less then 500 frames. If larger  split it into 500 frame segments and render the segments to video files. Then  use menu File>Import>Video Frames to Layers.
          That way you can get the frames. Converting video to frame animation seems to create a single frame for each video segment...
