6 Replies Latest reply on Apr 9, 2013 7:09 AM by BEGINNER_X
    Image Problem
    BEGINNER_X Level 3
      Hi All,
      Request:
      For my script I want to copy all graphics from source document and paste in target document.
      But for one particular art, the script is quit. That art name not comes in "Link" also (refer screenshot).
      I dont know what format it is like tiff, eps etc.....
      Please find the screenshot:
      Trying Script(work fine all arts exept above mentioned art):
      var mySourceDocument = app.documents[0]
      var myDocName = mySourceDocument.name
      myDocName = myDocName+"";
      var ImageSizes = new Array;
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
        var docSource = app.documents.item(myDocName);     // input the proper name
      var docDestination = app.documents.item("testing.indd")     // input the proper name
      var myGraphics = mySourceDocument.allGraphics
      for (i = 0; i < myGraphics.length; i++) {
              var myGraphicsName = myGraphics[i].itemLink.name;
                  myGeometricBounds = myGraphics[i].parent.geometricBounds
           var myWidth = myGeometricBounds[3] - myGeometricBounds[1]
           var myHeight = myGeometricBounds[2] - myGeometricBounds[0]
          if (i == 0) {
              app.activeWindow = docSource.windows.item(0);
              app.select(myGraphics[i].parent);
              app.copy();
              app.activeWindow = docDestination.windows.item(0);
              app.paste();
          if (i != 0) {
              app.copy();
              app.paste();
      Please find the error screenshot while running the script:
      Could anyone give solution for my problem.
      BEGINNER_X
        • 1. Re: Image Problem
          Kasyan Servetsky Level 5
          This image was created by copying it from another application and pasting it into InDesign. That's why it is not a link and has no itemLink property. The error occurs when the script tries to access it.
          • 2. Re: Image Problem
            BEGINNER_X Level 3
            Hi Kasyan,
            Thanks for your quick response..
            Please give any solution for my script for copy and paste from source document and target document.
            Customer using that kind of art also.
            Trying in below way. It not to be sucess
            LinkStatus.NORMAL
            LinkStatus.LINK_OUT_OF_DATE
            LinkStatus.LINK_MISSING
            LinkStatus.LINK_EMBEDDED
            LinkStatus.LINK_INACCESSIBLE
            BEGINNER_X
            • 3. Re: Image Problem
              As far as I know, placing an image without creating a link (by coping & pasting) is possible on Mac only. But I'm currently on PC.
              • 4. Re: Image Problem
                You are not using the variable "myGraphicsName" *anywhere* else in the rest of your script. What happens if you remove this line?
                • 5. Re: Image Problem
                  Vamitul Level 4
                  Kasyan, it's posibile on pc too.
                  Beginner, the entire
                  is unneded.
                  Also, try to avoid using copy and paste functions whenever possible, they slow down the script a lot.
                  Another note, you should make a habbit of ending your statements with ;
                  • 6. Re: Image Problem
                    BEGINNER_X Level 3
                    Hi Jongware/Vamitul/Kasyan,
                    Thank you for your response....
                    This one is part of  script only.
                    Image without link name on that time my script quit.
                    Now Using the below code without error:
                    try{
                    catch(myError)
                    Now my script works fine.
                    BEGINNER
