3 Replies Latest reply on May 17, 2016 12:33 PM by PaceCapJim
    How to add a custom web apps root page?
    MikeConnolly Level 2
      I saw in Jan 2013 System Update the following:
      "Render a custom page when accessing the root URL of a Web App. For example, if you have a “blog” Web App, the items can be made accessible at  /blog/my-blog-post, and you’ll have the ability to customize the /blog page"
      Could someone point me in the correct direction for instructions on how to make use of this feature.
      Couldn't appear to find a link from the Blog release notes to anything, and also tried trawling through support and forums for a suitable post.
      Closest I found was one about using sub-folders for web app items.
      I've tried adding a page in website admin, with the same URL as the web app, but it simply throws an error as it clashes with Web App url.
      Cheers
      Mike
        • 1. Re: How to add a custom web apps root page?
          Liam Dilley Adobe Community Professional & MVP
          Hi Mike.
          Because a folder can have a index.html Web apps in the past you could not access that ability. You had to make a page and you could not SEO call it the same as your web app.
          SO
          Your web app is called Blog.
          You can now make a folder in your root called Blog.
          In that folder you can create a page and give it a url of index.html
          Now when you access the a web app directly - www.yoursite.com/yourwebapp or www.yoursite.com/yourwebapp/index/html you will access that index page.
          You can also put other pages under that folder if you want too.
          • 2. Re: How to add a custom web apps root page?
            Once again Liam a fanatastic help!
            Cheers
            Mike
            • 3. Re: How to add a custom web apps root page?
              PaceCapJim
              Is there still no method for rendering a truly clean web app "root page", i.e., one that uses the exact same "displayed" path to the web app root (/webapp) as used when displaying items dynamically generated by the web app (/webapp/item-name), or does a BC user just have to take whatever SEO hit comes from using a different syntax for the web app "root" URL (the addition of .htm/.html).
              Obviously, there's some sort of underlying structural issue with BC's code, so I guess the real question is why BC doesn't care to fix it? It's clearly possible with almost any Apache/PHP based architecture (I know from experience using Wordpress, Drupal, and a couple of ecommerce platforms). Lisewise, according to this post, the same is also possible with IIS/ASP.NET (SEO For ASP.NET Web Sites: URLs ).
              Thanks in advance for anyone's guidance.
