1 Reply Latest reply on Nov 14, 2007 5:57 AM by
    how can I dynamically change a Grids ro color
    ljonny18
      I am using a grid within a component in my Flex application.
      I have an XML dataProvider, and I want to change the row colour of my Grid depending on a value coming form my dataProvider – but I cant seem to get this to work :(
      can anyone help / advise me on how I can dynamically change the colour of my grid row depending on a value coming from my XML DataProvider????
      For example:
      Within my component I have the following grid within an “MXML” component called myGrid.mxml:
      [CODE]<mx:Grid id="GGrid">
      <mx:GridRow backgroundColor="0xCFD8DA">
      <mx:GridItem>
      <mx:Label id=”name_lbl”/>
      </mx:GridItem>
      </mx:GridRow>
      <mx:GridItem>
      <mx:Label id=”expiryDate_lbl”/>
      </mx:GridItem>
      </mx:GridRow>
      <mx:GridRow id=”statusRow”>
      <mx:GridItem>
      <mx:Label id=”status_lbl”/>
      </mx:GridItem>
      </mx:GridRow>
      </mx:Grid>[/CODE]
      I am setting/declaring my results/variables form my dataProvider in the main Application (“MXML”) file:
      <mx:Application
      xmlns:mx=" http://www.adobe.com/2006/mxml"
      xmlns="*"
      creationComplete="initApp()" >
      <mx:HTTPService
      id="myResults"
      url=" http://localhost/myResults.xml"
      resultFormat="e4x"
      result="myResultHandler(event)" />
      [CODE]<mx:Script>
      <![CDATA[
      import mx.core.Application;
      [Bindable]
      public var myDataFeed:XML;
      public function initApp():void
      myResults.send();
      public function myResultHandler(event:ResultEvent):void
      myDataFeed = event.result as XML;
      Application.application.myGrid.name_lbl.text = myDataFeed.name;
      Application.application.myGrid.expiryDate_lbl = myDataFeed.expiry;
      Application.application.myGrid.status_lbl.text = myDataFeed.status;
      if(myDataFeed.status == “OK”)
      Application.application.statusRow.backgroundColor="0xCFD8DA";
      else if (myDataFeed.status == “WARNING”)
      Application.application.statusRow.backgroundColor="0xFF9900";
      else if (myDataFeed.status == “CRITICAL”)
      Application.application.statusRow.backgroundColor="0xFF0000";
      </mx:Script>
      </mx:Application>[/CODE]
      however, I cannot access the property “backgroundColor” of the gridRow in this way:
      [CODE]Application.application.statusRow.backgroundColor[/CODE]
      As I get the following error:
      [CODE]Severity and Description Path Resource Location Creation Time
      Id 1119:
      Access of possibly undefined property backgroundColor through a reference with static type mx.containers:GridRow. enterpriseDB_new enterpriseDB_new.mxml
      line 721 1194443056449 19295[/CODE]
      Jon.
        • 1. Re: how can I dynamically change a Grids ro color
          quote:
          Originally posted by: ljonny18
          Jon.
          a few hours ago I stumbled across this cookbook entry - it didn't solve MY problem, but maybe it provides a way to solve your problem?
          http://www.adobe.com/cfusion/communityengine/index.cfm?event=showdetails&postId=61&product Id=2&loc=en_US
          From the article:
          quote:
          Changing the background color of a DataGrid cell is not as simple as changing some style because the default renderer for a DataGrid cell does not have a backgroundColor. Therefore, to do this simple task, you have to create a custom itemRenderer where you draw your own background in the updateDisplayList function.
          HTH
          Uwe
