1. Re: Component edit mode not working
Sham HC Apr 14, 2013 8:14 PM (in response to Veena_07)Hi Veena,
Please verify in the browser console. You should see some javascript error. Paste the error stack trace.
Sham
2. Re: Component edit mode not working
Veena_07 Apr 15, 2013 6:48 AM (in response to Sham HC)Hi Sham
I cud see only this
Uncaught Error: IndexSizeError: DOM Exception 1
veena
3. Re: Component edit mode not working
Sham HC Apr 19, 2013 8:10 PM (in response to Veena_07)Hi Veena,
Is it happening in chrome or any other browser? In your dialog are you using any cqinclude?
4. Re: Component edit mode not working
Veena_07 May 2, 2013 5:16 AM (in response to Sham HC)Hi Sham
It is happening with chrome and Mozilla.. Ie8 it is working
Veena
5. Re: Component edit mode not working
Sham HC May 3, 2013 2:43 PM (in response to Veena_07)Hi Veena,
dialog of custom component might be causing it. There should be file name after "Uncaught Error: IndexSizeError: DOM Exception 1" the exception.
If you are using oob components then paste your dialog.xml
Sham
@adobe_sham
6. Re: Component edit mode not working
Asa B Jun 12, 2013 11:14 AM (in response to Sham HC)Hi Sham,
Im seeing a simular issue. In my case the error "DOM Exception 1" is thrown in Chrome latest for CQ5.5
When an authour begins editing the Rich Text Component, this error occurs intermitently. Debugging clientLibs shows the following...
http://localhost:4502/libs/cq/ui/widgets/source/widgets/form/rte/Selection.js
line #2052 -
7. Re: Component edit mode not working
Sham HC Jun 16, 2013 4:17 PM (in response to Asa B)For 5.5 chrome is not fully supported[1] & the issue is logged CQ5-29304
[1] https://dev.day.com/docs/en/cq/5-5/deploying/technical_requirements.html
8. Re: Component edit mode not working
Asa B Jun 28, 2013 8:49 AM (in response to Sham HC)Hi Sham,
Im sure I dont understand, Chrome is correctly implementing W3C spec.
Here's an excerpt from Mozilla concerning the index parameter of the getRangeAt method
https://developer.mozilla.org/en-US/docs/Web/API/Selection/getRangeAt
"The zero-based index of the range [should] return. A negative number or a number greater than or equal to rangeCount will result in an error"
In other words Chrome is correctly throwing an error in accordance with W3C spec.
MS IE<=8 does not support .getRangeAt(); so it must be using alternate code as it cannot invoke getRangeAt. While I understand that CQ5.5 is not "supporting" Chrome, this defect is in code specifcaly written by Adobe to support modern capable browsers and there is a bug in it.
