1 Reply Latest reply on Apr 10, 2013 2:32 AM by GuanshuaiQiao
    Adding a Repeating Field
    jeffkab17
      Can I add a repeating field in a PDF, one where the end user can select to duplicate a field when filling out a form?
      Thanks for your help!
      Jeff
        • 1. Re: Adding a Repeating Field
          GuanshuaiQiao
          You can create a form with duplicated field in FormsCentral, then export it to Submission-Enabled PDF. But you may not add a repeating field in PDF, then import form to FormsCentral. but there's no limitation if you create PDF form with duplicated field, use it locally.
