jl,
When you select "W3 compliant topics" in the WebHelp setup,
the RH 7 topic output files have this as the first line:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01
Transitional//EN">
Does this meet the standard? If not, why not?
RH project files, including the topic source files, don't
have this line. The project source files are not intended for
display on the WWW.
Also, the other .htm output files (i.e., not the topics, but
those for WebHelp processes) do not have this line.
Do you see a problem here?
Thanks.
Harvey
(I shot from the hip earlier; the above is correct.)
P.S. I see some other differences in syntax for js and tags,
but I don't know enough to make a generalization, beyond this:
The differences apparently remove some RH html code that
might not "meet W3 standards." I'm guessing, and maybe Adobe can
confirm this, the code doesn't violate any explicit W3 rules, but
isn't specifically part of their library.
But I wholeheartily agree with Leon that browsers don't get
upset about it.
H
