2 Replies Latest reply on Apr 10, 2013 4:10 AM by aklimets
    How to set cq:tags property of the code through JCR 2.0
      I am trying to set the value of cq:tags programtically through JCR 2.0. When I execute this code
           Session session = repository.login( new SimpleCredentials("admin", "admin".toCharArray()));
                                    Node n12 = session.getNode("/content/testprop_content");
                                    session.getWorkspace().getVersionManager().checkout("/content/testprop_con tent");
                                    Node n1 = session.getNode("/content/testprop_content/jcr:content");
                                    System.out.println("Node n1:"+n1.getName());
                                              n1.setProperty("cq:tags", arr);
                                              n1.setProperty("jcr:title","My custom title" );
      the value of property jcr:title is set, but cq:tags it is coimg blank , where arr is an array containing 3 values. Am I doing something wrong.
      Please let me know how to set the value of property cq:tags through code using jcr 2.0 or jackrabbit apis.
        • 1. Re: How to set cq:tags property of the code through JCR 2.0
          krzysztof grams
          I've replicated your problem. If tags you have inseretd in your array does not exist in your repository, n1.setProperty("cq:tags", arr) method leaves attribute empty. If you first add tags inside repository n1.setProperty("cq:tags", arr) sets attribute with values in arr.
          Hope it's helpful
          • 2. Re: How to set cq:tags property of the code through JCR 2.0
            aklimets Adobe Employee
            The cq:tags property must point to existing tags - otherwise they are ignored and can/will be removed.
            You should usually not work with raw cq:tags properties, but use the tagging API.
            Citing the docs:
            The implementation of the tagging framework in CQ allows to manage tags and tag content solely by using the JCR API. It ensures that tags set in the cq:tags property are not duplicated, it removes IDs pointing to non-existing tags and updates tag IDs for moved or merged tags. It is done by using a JCR observation listener that reverts any incorrect changes.
            Note that it's not setProperty() itself, but an event listener that removes the invalid references asynchronously, but quickly after the session save().
