4 Replies Latest reply on Apr 10, 2013 8:22 AM by TᴀW
    Missing Open type small caps
    Lars Bo Zhou Yi
      Hi-
      I am using the Arno Pro font which gives the option "Open Type small caps" on my friends ID 5.5.
      However, on my ID 6.0 it only gives the option to choose "Open Type all small caps".
      The font seems to be properly installed, why can it be it is not there? LarsUdklip.JPG
        • 1. Re: Missing Open type small caps
          You should see a choice for Small Caps, second in the list. That will use the built-in small caps in any font that has them, such as Arno Pro.
          • 2. Re: Missing Open type small caps
            Lars Bo Zhou Yi Level 1
            Is this new in CS6? because I'm sure I have seen an option to choose Open Type small caps in earlier versions.
            • 3. Re: Missing Open type small caps
              It's been this way since at least CS3.
              • 4. Re: Missing Open type small caps
                TᴀW Adobe Community Professional & MVP
                Hold on. There's always been an option to choose between all small caps,
                and mixed caps/small caps, and that still exists in CS6.
                The "small caps" button on the control panel will give you small caps,
                whereas control panel>OpenType>All small caps will give you "all small
                caps".
                Alternatively, the flyout from the character palette gives you "small
                caps", whereas if you choose OpenType from that flyout, you'll see the
                option for "all small caps".
                Third option: In the character style dialog, the dropdown by "case"
                gives you the option for "Small Caps" and "OpenType All Small Caps".
                The point to note here is that both options are (somewhat misleadingly)
                giving you REAL OpenType small caps, if available in the font (and the
                font is properly made, which Arno Pro is!). The only difference is that
                one is caps&smallcaps, and the other is all small caps.
                Ariel
