6 Replies Latest reply on Apr 10, 2013 5:15 AM by rajnikids
    Please fix my bit of script for IDML
    rajnikids Level 1
      if (app.activeDocument!=null ) {
      var myDoc = app.activeDocument.save(File(Folder('//Users/Desktop/LW_Qxd_conversion_indd/IndesignFile' )+ "/" + app.activeDocument.name), true);
      var mDoc = app.activeDocument;
      mPath = mDoc.filePath.parent + '/' + "tmp";
      myFilename = app.activeDocument.fullName.toString();
      //~ mPathDoc = app.activeDocument.fullName;
      if (myFilename.match(".indd") !=null){
      myFilename = myFilename.split(".")[0]+"idml";
      mDoc.exportFile(ExportFormat.INDESIGN_MARKUP, File(Folder('//Users/QXP_8_4_2013/Indesign_CS4')+ "/" + app.activeDocument.name), true);
      app.activeDocument.close(SaveOptions.no);
      The above script export only one file as IDML after then the script just stops. Can anybody helps on this to export all the open document as IDML.
      THANKS. & REGDS.,
        • 1. Re: Please fix my bit of script for IDML
          Vamitul Level 4
          loop thtoug the documents.
          Simplest fix:
          add this first two lines
          for (var qq=0; qq<app.documents.length; qq++){
          app.activeDocument=app.documents[qq];
          and
          last line add a }
          ps. it's a ugly way of fixing your problem, but i'm too lazy to change your code.
          • 2. Re: Please fix my bit of script for IDML
            rajnikids Level 1
            thanks vam!
            but what happens is,
            it leave atleast 3 document un exported as IDML/unclosed (if the open document count is atleast more than 6).
            it leave atleast 2 document unexported as IDML/unclosed (if the open document count is atleast 5 documents).
            any help please...
            thanks & regards,
            • 3. Re: Please fix my bit of script for IDML
              rajnikids Level 1
              thanks vam!,
              now i got the point, actually its because of the system speed up..
              thanks vam! many apologises for the above post.
              thanks & regards,
              rkids
              • 4. Re: Please fix my bit of script for IDML
                rajnikids Level 1
                vam! not an ugly!
                you have added a  great effort to my effort.
                Actualy im including this in my quark to indesign conversion script and directly exporting as idml.
                it really a great help indeed!.. thanks vam.
                • 5. Re: Please fix my bit of script for IDML
                  Vamitul Level 4
                  if it's part of a larger script i suggest doing things properly:
                  for (var i = 0; i < app.documents.length; i++) {
                            var myDoc = app.documents[i];
                            myDoc.save(File(Folder('//Users/Desktop/LW_Qxd_conversio n_indd/IndesignFile') + "/" + myDoc.name), true);
                            mPath = myDoc.filePath.parent + '/' + "tmp";
                            myFilename = myDoc.fullName.toString();
                            if (myFilename.match(".indd") != null) {
                                      myFilename = myFilename.split(".")[0] + "idml";
                                      mDoc.exportFile(ExportFormat.INDESIGN_MARKUP, File(Folder('//Users/QXP_8_4_2013/Indesign_CS4') + "/" + myDoc.name), true);
                                      myDoc.close(SaveOptions.NO);
                  • 6. Re: Please fix my bit of script for IDML
                    rajnikids Level 1
                    again & again so much thanks to you vam!!
                    really great and appreciatable.
                    thanks & regards,
                    rkids.
