4 Replies Latest reply on Apr 14, 2013 9:58 AM by Jim_Simon
    Clip out of synch video and audio in Premiere and Encoder
    filmmakervixen
      I have a few files that for some reason play alright but when I import them to the timeline in Premiere or into Encoder to reduce their size the video is completely out of synch with the audio. The clip is 29.907 fps no matter what attributes I seem to to adjust the clip will not synch. Any help would be much appreciated.
        • 1. Re: Clip out of synch video and audio in Premiere and Encoder
          Three things...
          First, general questions
          More information needed for someone to help... please click below and provide the requested information
          -Information FAQ http://forums.adobe.com/message/4200840
          Second, what are you editing?
          Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
          What is a CODEC... a Primer http://forums.adobe.com/thread/546811
          What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
          Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
          http://forums.adobe.com/thread/592070?tstart=30
          For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
          For Mac http://mediainspector.massanti.com/
          Third, are you doing this?
          For CS5 and later, the easy way to insure that your video and your project match
          See 2nd post for picture of NEW ITEM process http://forums.adobe.com/message/3776153
          -and a FAQ on sequence setting http://forums.adobe.com/message/3804341
          • 2. Re: Clip out of synch video and audio in Premiere and Encoder
            filmmakervixen Level 1
            Ok here goes:
            I have a few files that for some reason play alright but when I import  them to the timeline in Premiere or into Encoder to reduce their size  the video is completely out of synch with the audio. The clip is 29.907  fps no matter what attributes I seem to to adjust the clip will not  synch. Any help would be much appreciated. 30 clips out of over 800 are doing this..
            CS6
            Encoder 6
            All updated
            OSX10.8.3
            H264 as a MP4
            No error messages
            Happens in preview and final output
            No 3rd party codecs
            MBP Retina Display
            Mercury Playback
            General
            Complete name                    : Desktop/BE HEALTHY ISSUE/01BeHealthy_Demointro_clips1-3.mp4
            Format                           : MPEG-4
            Format profile                   : Base Media / Version 2
            Codec ID                         : mp42
            File size                        : 17.5 MiB
            Duration                         : 1mn 44s
            Overall bit rate                 : 1 402 Kbps
            Encoded date                     : UTC 2012-12-23 05:44:46
            Tagged date                      : UTC 2013-04-12 00:45:37
            Video
            Format                           : AVC
            Format/Info                      : Advanced Video Codec
            Format profile                   : Main@L2.0
            Format settings, CABAC           : No
            Format settings, ReFrames        : 2 frames
            Format settings, GOP             : M=2, N=24
            Codec ID                         : avc1
            Codec ID/Info                    : Advanced Video Coding
            Duration                         : 1mn 44s
            Duration_LastFrame               : 5mn 4s
            Bit rate mode                    : Variable
            Bit rate                         : 1 284 Kbps
            Width                            : 220 pixels
            Height                           : 180 pixels
            Display aspect ratio             : 1.222
            Frame rate mode                  : Constant
            Frame rate                       : 29.970 fps
            Color space                      : YUV
            Chroma subsampling               : 4:2:0
            Bit depth                        : 8 bits
            Scan type                        : Progressive
            Bits/(Pixel*Frame)               : 1.082
            Stream size                      : 16.0 MiB (92%)
            Language                         : English
            Encoded date                     : UTC 2012-12-23 05:44:40
            Tagged date                      : UTC 2012-12-23 05:44:46
            Color primaries                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
            Transfer characteristics         : BT.709-5, BT.1361
            Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
            Audio
            Format                           : AAC
            Format/Info                      : Advanced Audio Codec
            Format profile                   : LC
            Codec ID                         : 40
            Duration                         : 1mn 44s
            Bit rate mode                    : Constant
            Bit rate                         : 112 Kbps
            Nominal bit rate                 : 128 Kbps
            Channel(s)                       : 2 channels
            Channel positions                : Front: L R
            Sampling rate                    : 48.0 KHz
            Compression mode                 : Lossy
            Stream size                      : 1.40 MiB (8%)
            Language                         : English
            I am really baffled at this. At first I thought the smaller versions I had done to reduce to file size were just messed up by user error when I exported them from Encoder but for some reason the first 30 or so files of 81 files are totally out of synch in preview of CS6 and the timeline and no matter how I export them out of the Encoder.
            Help is much appreciated!
            • 3. Re: Clip out of synch video and audio in Premiere and Encoder
              Here is an example file that when put onto the Premiere timeline or into Encoder plays out of synch.
              https://dl.dropboxusercontent.com/u/52083002/01BeHealthy_Demointro_clips1-3.mp4
              • 4. Re: Clip out of synch video and audio in Premiere and Encoder
                Jim_Simon Level 8
                The file is giving PP a problem.  It's not exactly standard camera media.  I'd recommend getting a new version that conforms to one of the standards PP works with.
