1 Reply Latest reply on May 10, 2013 6:55 AM by 2007ay
    Can i create a xmlDocument in Adobe ExtendScript toolkit
    2007ay
      hi all,
      i am using Adobe extendScript toolkit to write plugin for Adobe illustrator.
      and the same time i also want to convert my application object in to xml Document .
      first of all i want to know whether its is possilble? if yes know how ?
      as of know i used the given below code but its throwing some error "DOMParser dont not have constructor "
      function createXmlDocument(string)
          var doc;
          if (window.DOMParser)
              parser = new DOMParser();
              doc = parser.parseFromString(string, "application/xml");
          else // Internet Explorer
              doc = new ActiveXObject("Microsoft.XMLDOM");
              doc.async = "false";
              doc.loadXML(string);
          return doc;
      NOTE: actully i want to convert app.activeDocument in to xml documents (exc : docutmen1.xml).
      thanks
      Regards
      Ashish.
        • 1. Re: Can i create a xmlDocument in Adobe ExtendScript toolkit
          2007ay Level 1
          luckly i sloved my problem by the api given in extend java script;  the ans is :  read the file as string and use var xmlDoc = new XML(strData); it will convert ur strdata into xmlDocument exp
          :var xmlString =  <body>
          <div id="Layer_1" class="Layer_1">
          <div id="TextFrame_1" class="TextFrame_1"> This is the text Examples </div>
          </div>
          </body>
          try
          var xmlDocument = new XML (xmlString);
          }catch (e)
          alert(e);
          Regards
          ashish yadav
