3 Replies Latest reply on Apr 15, 2013 3:25 PM by Kevin Sherrill
    Flash builder 4.7 throwing errors for no reason - is there a fix?
    rickwillett Level 1
      errorAgain.jpg4.jpgHello,
      I am using FB4.7, right now on an AS project. For some reason, FB has started "locking up" on runtime errors. Meaning, if I run a code with an error, then fix the error, FB still reports an issue at that line, even if the line is blank.
      In the attached image, you can see that I am getting a 1009 Error on the second reference to a variable that has been declared directly above - obviously a bs error.  I had a chunk of code there before, that did have the error, but I am still getting the Error, can't test, compile, etc.
      Very frustrating, no idea what is causing this!!! Thanks for any input!
      FB 4.7 Win7
        • 1. Re: Flash builder 4.7 throwing errors for no reason - is there a fix?
          Kevin Sherrill Level 1
          Sorry, I don't know the cause of your error.
          Although I'm relatively new to FB (I've previously developed mostly in Flash Pro) I've run into something similar I think.
          Sometimes FB is looking at object compiled and sitting in your debug-bin folder. After you fix a bug and it doesn't go away, then do a project clean and that might clear it up.
          • 2. Re: Flash builder 4.7 throwing errors for no reason - is there a fix?
            rickwillett Level 1
            Thanks Kevin,
            I have tried cleaning, and getting rid of the bin-debug, but the behavior seems to either come back quickly or not go away at all. I thought it was localized to new projects, but older imported projects are doing the same thing. Hopefully there is a permanent fix I am not seeing.
            • 3. Re: Flash builder 4.7 throwing errors for no reason - is there a fix?
              Looks like its dying on the first line of code in that method. Try checking:
              The methods parameters - perhaps compiler doesn't like TextFormat defaulting to null
                 Or perhaps you're using that default null param and its biting you but misreporting the line number.
                 Seems like I might have had problems in the past with params, but I think it was with assigning null to a callback function param.
                    Instead I had it default to an empty class method called NullMethod, or some such.
              Other ideas, although these usually apply to compile time errors and not runtime:
              Import statements - are you missing one?
              Access modifiers - is something trying to call this method that doesn't have access?
              Check for syntax errors higher in the file.
