1 Reply Latest reply on Apr 12, 2013 3:59 PM by Mandy_Wiesener
    Dynamic Tables help
    Aditi208
      If I have a table and I want some rows  to be dynamic and others not is this possible? (for example rows 1-4 don't need to be dynamic but row 5 does).
      How would I do this?
      I tried making two seperate tables and making each table it's own subform and setting the one I need and the whole form as Flowed content but it doesn't work. is it because I have two tables?
        • 1. Re: Dynamic Tables help
          Mandy_Wiesener Level 3
          Yes of course.
          You create your table.
          In the dynamic rows the textobjects get two properties
          • The static textobjects needs only "limit lengths to visible area".
          • Then you wrap the table into a subform. This subform needs "content" "flowed". (object | subform)
          • Then the subform of the page needs the same settings. ("content" "flowed". (object | subform))
          • Then save the form as dynamic.
          In the example I make the Row 1 and 4 dynamic.
          https://workspaces.acrobat.com/?d=CZX-iFKubKFaJWFz7Y3fow
          Hope it will helps,
          Mandy
