0 Replies Latest reply on Apr 12, 2013 3:23 PM by reds72
    How can I set an images height/width to display in inches for an iOS app?
    reds72
      I am currently attempting to return the name of the device, then manually assigning a DPI.  I am then multiplying that DPI times the number of inches that the image will display at.  Here are the two functions used to determine the device and set the DPI:
      function getDevice():String {
                var devFinal:String;
                var devStr:String = Capabilities.os;
                var devStrArr:Array = devStr.split(" ");
                devStr = devStrArr.pop();
                devStr = (devStr.indexOf(",") > -1)?devStr.split(",").shift():debuggerDevice;
                if ((devStr == "iPad1") || (devStr == "iPad2")){
                                              devFinal = "ipad";
                                    } else if ((devStr == "iPad3") || (devStr == "iPad4")){
                                              devFinal = "ipad3";
                                    } else {
                                              //This will be the iPad Mini
                                              devFinal = "ipadmini";
                                    return devFinal;
      function getDPI():int {
                var retDPI:int;
                if (currentDevice == "ipad"){
                          retDPI = 132;
                else if (currentDevice == "ipad3"){
                          retDPI = 264;
                else if (currentDevice == "ipadmini"){
                          retDPI = 163;
                else {
                          retDPI = 132;
                return retDPI;
