1. Re: Text frame baseline problem
Steve Werner Apr 13, 2013 5:22 AM (in response to HSGROW_HK)Somebody probably has written (or will write) a script to do that.
2. Re: Text frame baseline problem
P Spier Apr 13, 2013 6:16 AM (in response to HSGROW_HK)I think, too, that if you set the text frame otions before you start importing they will be honored as the default for the file. Since you've already placed text, though, the first thing I would try is editing the [Basic Text Frame] object style, or whatever object style is assigned if you didn't use Basic Text Frame.
3. Re: Text frame baseline problem
HSGROW_HK Apr 13, 2013 9:01 AM (in response to P Spier)Hi Peter,
Thanks for the tip. In ID CS6, the following optons are given when importing a word doc. Where should I be going to set the text frame options?
Or do you mean that I should make a text box and then pplace into it? Normally what I do is hold shift+click on the margin, then all the necessary pages are auto created.
4. Re: Text frame baseline problem
Ellis home Apr 13, 2013 10:05 AM (in response to HSGROW_HK)If I'm not mistaken, I think Peter was referring to set the text options before importing, in your ID document: Object/Text Frame Options.
5. Re: Text frame baseline problem
[Ariel] Apr 13, 2013 11:22 AM (in response to Ellis home)In the find/change box, under the object tab, search for all text frames
and replace with the object style you would like.
Ariel
6. Re: Text frame baseline problem
That's correct.
7. Re: Text frame baseline problem
HSGROW_HK Apr 13, 2013 11:37 PM (in response to P Spier)Thank you Ariel and Peter. Problem solved! Much apreciated.
