0 Replies Latest reply on Apr 12, 2013 11:50 PM by kzsombor
    LiveCycle - SOAP, read data to blob
    kzsombor
      Dear,
      I'm trying to call a lc web service from c#
              PDFUtilityServiceClient client = new PDFUtilityServiceClient();
              client.ClientCredentials.UserName.UserName = "administrator";
              client.ClientCredentials.UserName.Password = "password";
              string version = client.getVersion();
      returning: "11.0.0.20130128.2.324633"
      When I try to call convertXdpToPdf I get Fault Exception:
      "Caused by: com.adobe.livecycle.pdfutility.client.PDFUtilityException: ALC-UTL-S04-005: Failed to convert document to a PDF document. Caused by: com.adobe.internal.pdfutil.PDFUDocHandleException: ALC-UTL-S02-014: The XDP document could not be opened.; nested exception is:
          com.adobe.livecycle.pdfutility.client.PDFUtilityException: ALC-UTL-S04-005: Failed to convert document to a PDF document."
      I guess I made some mistake when creating the blob object. I've made the xdp file with designer and saved the form as xdp.
      BLOB input = new BLOB();
      input.binaryData = Encoding.ASCII.GetBytes(File.ReadAllText(@"C:\adobe\alma.xdp"));
      var result = client.convertXDPtoPDF(input);
      client.Close();
      I've also tryed different encodings also in reading the file, further reading the whole file in binary
      File.ReadAllByte(@"C:\adobe\alma.xdp");
      With the same result. What else parameters should be filled in the BLOB object:
              contentType
              remoteURL
              ExtensionData
      and how to add the xml file properly
      thanks in advice:
         gimp
