5 Replies Latest reply on Apr 15, 2013 10:55 PM by Rick Gerard
    no shadows with gradient
    Arrakis Level 1
      I have a shape with a 4 colour gradient on it but it wont accept shadows unless i turn off the gradient. Is there a way to have shadows on this shape and keep the gradient as well?
        • 1. Re: no shadows with gradient
          Todd_Kopriva Level 8
          We don't have enough information about your composition to be able to answer your question. Showing screenshots of your Timeline panel and your Composition panel is a good start toward showing us what your setup is.
          • 2. Re: no shadows with gradient
            Arrakis Level 1
            A picture is nor neccessary for my question.
            My comp has 2 layers -
            solid as floor has 4 colour gradient
            Above that is a circle sitting upon the floor
            I have a light shining onto the cirlce to cast a shadow on the floor.
            The floor does not accept shadows unless the gradient is switched off.
            It seems obvious to me that layers with gradient simply do not accept shadows, its just a limitation of AE however, I wanted a solution to see if there is a workaround. That is all.
            • 3. Re: no shadows with gradient
              As always: In case of doubt, pre-compose. Now your description is a bit vague, but effects normally don't affect 3D rendering, only layer styles do. If you use a gradient overlay layer style, this would be expected. Otherwise you may be introducing the problem somewhere else.
              Mylenium
              • 4. Re: no shadows with gradient
                Arrakis Level 1
                Thanks I precomposed and all is good.
                • 5. Re: no shadows with gradient
                  You should also consider creating gradients with a shape layer. It's much more useful than any of the other gradient tools in AE. You can even blend several different gradients to get something like this:
                  The point is that with a shape layer and multiple gradient fills using different blend modes you can create just about any kind of gradient you want and it will catch a shadow without pre-composing.
