6 Replies Latest reply on Apr 16, 2013 2:46 PM by CindyJones-Hulfachor
    Problem turning XML imported data to a number
    CindyJones-Hulfachor Level 1
      Asking for help, I am trying to turn XML data into a number that I can use in formulas in Animate. This is a simplified example of what I am trying to do. I have successfully retrieved the info from the xml file into the text on the stage. My problem is that I need to have the value of the imported data to be a number so that I can do future calculations with it, like add the two numbers together to make a new variable total. I have racked my brain reading about XML, spent several days trying obvious solutions to no avail, and yes I am new to coding although I have thoroughly tried many options.
      Thank you, Cindy J-H
      -----IMPORTING AN XML FILE "textimport.xml"
      <?xml version="1.0" encoding="UTF-8"?>
      <mediansaleschart>
      <figureone>20</figureone>
      <figuretwo>10</figuretwo>
      </mediansaleschart>
      ------EDGE ANIMATE CODING in Stage/creationComplete
      $.ajax({
                 type: "GET",
                 url: "textimport.xml",
                 dataType: "xml",
                 success: function(xml) {
      textOne = $(xml).find('figureone').text();
      textOneTxt.html(textOne);
      textTwo = $(xml).find('figuretwo').text();
      textTwoTxt.html(textTwo);
      var textOneTxt = $(this.lookupSelector("textOneTxt"));
      var textTwoTxt = $(this.lookupSelector("textTwoTxt"));
      ------EDGE ANIMATE ELEMENTS ON THE STAGE, text items
      textOneTxt
      textTwoTxt
        • 1. Re: Problem turning XML imported data to a number
          heathrowe Most Valuable Participant
          To get the value of the xml node you need to use parseInt.
          So for the total, I did something like this
                 myTotal = parseInt(figureone) + parseInt(figuretwo);
          You should also make use of the latest lookup reference
               instead of
               use this notation
                  sym.$("textOneTxt");
          Here is an example - http://www.heathrowe.com/edge/xmlnum/
          Download - http://www.heathrowe.com/edge/xmlnum/xmlnum.zip
          ////////// Code on compositionReady //////////////////////
          var figureone, figuretwo, myTotal;
          var outputField = sym.$("xmlOutput");
          var messageString;
          $.ajax({
          type: "GET",
          url: "sampleoutput.xml",
          dataType: "xml",
            figureone = $(xml).find('figureone').text();
            figuretwo = $(xml).find('figuretwo').text();
            messageString = "Figure One Value is: "+figureone+
              "<br>Figure Two Value is: "+figuretwo+
              "<br>Total Value is: "+myTotal;
            outputField.html(messageString);
          ///////////////// End Code ////////////////////////
          hth
          Darrell
          • 2. Re: Problem turning XML imported data to a number
            Darrell,
            Thank you so much. I have went through the download files that you made available and noted several areas where I had issues. Now I can move forward bringing the data into the other calculations that I have built. Have a great day!
            Cindy J-H
            • 3. Re: Problem turning XML imported data to a number
              Your welcome, Cindy.
              Darrell
              • 4. Re: Problem turning XML imported data to a number
                One additional concern: You have shown me how make xml data read as numbers inside the Ajax success function.
                Could you tell me how to make the variable myTotal read as a "Number" after it is sent out of the Ajax function.
                I plan on using retrieved xml data, outside ajax, to build  functions to run on many items.
                I would have thought I could have said:
                Number(myTotal);
                var newTotal = myTotal *1;
                or parseInt(myTotal);
                Thank you,
                Cindy
                • 5. Re: Problem turning XML imported data to a number
                  Hi Cindy see additions (bold) and notes appended below to the original
                  code.
                  hth
                  Darrell
                        var figureone, figuretwo, myTotal, myNewTotal;
                        var messageString;
                            $.ajax({
                                 type: "GET",
                                 dataType: "xml",
                                                     "Figure Two Value is: "+figuretwo+
                                                     "Total Value is: "+myTotal;
                                      customFunc(myTotal);                //  pass myTotal to a separate function
                            function customFunc(myTotal) {       // separate function receives myTotal
                                     var newtotal = myTotal*3;        // manipulate myTotal - multiplied by 3 and store in var called newTotal
                                  sym.$("Text").html(newtotal);    // pass the new value to an element on the stage called "Text"
                                   alert (newtotal);                           // or alert the result to a popup window.
                  • 6. Re: Problem turning XML imported data to a number
                    Darrell,
                    Thank you for your help. I see how the math works outside of the success function. I know in time this will come easier, it gets clearer every day, I just need to have more patience.
                    Cindy
