10 Replies Latest reply on Apr 16, 2013 8:52 AM by WiredMark
    Indesign wrong Bleed Area in PDF
    WiredMark
      I'm going to publish a book through a book-on-demand online service and I wanted some informations because I think there are problems with my Bleed Area in the PDF's exported from Indesign.
      My book is about 190 pages in A4, so I set its dimensions to 210 mm x 297 mm, with a Bleed Area on each side of 3,175 mm as stated on the online website.
      Since my background should extend on each side and I don't want white borders to appear on the page sides during the print, I extended the background to the bleed area, as the following picture (my facing pages master):
      When I export my book I get a strange result. Basically some pages have the inner bleed, that should contain the background I extended, totally white. Others, instead, have the copy of a part of the beginning of the previous page. Like this picture:
      This page is a new chapter, a new document of my indesign book. As you can see the bleed area on the left doesn't contains the background I extended but its white. Same happens with other pages, like the one of the chapter ending.
      Next you find the image of a common page in my book, as you can see the bleed area is fulled with the beginning of the background of another page.
      This is the PDF i get when exporting. I think something is wrong.
      I really need a lot of help on this, since I put much efforts in this project I would like to understand what I'm doing wrong now!
      Thanks a lot for any help!
      Marcello
