4 Replies Latest reply on Apr 15, 2013 12:57 PM by John T Smith
    Create a DVD | Video resolution issue - HD or FullHD
    SAngeli Level 1
      I created a new project selecting PAL and AVCHD 1920x1080 16:9 25fps video. The original AVCHD video in FullHD is 9GB.
      I now have to create a DVD and end the project selecting to burn it on a 4,7 GB DVD but wish to preserve the FullHD if possible.
      When selecting the option to burn the DVD I get in the drop down menu 4 selections being 2 for NTSC and 2 for PAL: PAL and PAL Widescreen.
      Obviously as the project is 16:9 I should select Widescreen but I do not know if I will end up having the video in FullHD.
      Here are my few questions:
      1. how to be able to burn a FullHD video project into a 4,7 GB DVD if i do not see any FullHD selection in the drop down menue for DVD category? Is this because DVD category does not manage FullHD?
      Reading through some manual I believe that it is AVCHD the selection I should use, rather than DVD. Is this correct?
      Also, what resolution would Pal Widescreen record?
      Lastly, how to find out which resolution i now have the project being burned on this DVD?
      2. If I know that my project in FullHD is bigger than  4,7 GB DVD what should I do, when I create a new Premiere EL project, in order to get the best resolution? Should I select still AVCHD but HD resolution even if I will not know if it will be sufficient?
      Can someone please share with me what is the correct discernment to use for preparing a new project and/or handling the video settings for getting the properl DVD result?
      Thank you
