2 Replies Latest reply on Apr 16, 2013 3:40 AM by andygkent
    Shakey/jumpy 'tween' in Content Viewer
      Hi, when placing a .oam file into indesign then previewing in the content viewer the 'tween' is not so smooth.
      Is this a content viewer issue? The animation is simply a 1 second file with content coming in off the stage in a linear movement.
      I want to be sure when published to the app store the final result will have a smooth movement.
        • 1. Re: Shakey/jumpy 'tween' in Content Viewer
          sarhunt Adobe Employee
          Hey Andy,
          Are you using the content viewer for the desktop or ipad? I'd recommend using the iPad, you'll get a native experience there while the desktop viewer is an emulation running on an outdated version of Webkit.
          • 2. Re: Shakey/jumpy 'tween' in Content Viewer
            andygkent Level 1
            Hi Sarah
            Thanks for the response. Yes, I'm using Content Viewer on my iPad as the desktop version crashes quite a lot.
            I'm assuming svg's are the best files to import, this animation has a couple of layers and it seems to jump at the start of the top layer, as if there's a slight (fraction of a second) processing lag. I'll try redrawing it and see if that makes a difference.
            Cheers, Andy
