6 Replies Latest reply on Apr 16, 2013 9:09 AM by ECBowen
    DECREASED performance with a Quadro 5000?
    pseudo-numb
      I'm building a Dell T7600 workstation for Premiere work.  After determining that the included Quadro K5000 is NOT listed as supported by Adobe for good reason, I purchased and installed a (listed) Quadro 5000.  Now, I'm doing some performance benchmarking and I found that performance DEGRADES when using GPU acceleration in Project Settings/General.
      OS - Win 7 Pro
      CPU - 1 @ Xeon 8 core
      RAM - 32 GB
      I/O - Integrated 3gb/s SATA via min-SAS
      HDD:
         C: - 2 TB Seagate 7200 - OS + CS5.5 Caching
         E: - 2 TB Seagate 7200 - Source files
        F: - 2 TB Seagate 7200 - Preview files
        G: - 2 TB Seagate 7200 - Export files
      RAM allocated to Adobe - 16GB
      Rendering work area before export
      Little or few effects
      Source Video -
      Image Size: 1440 x 900
      Frame Rate: 29.97
      Source Audio Format: 44100 Hz - 16 bit - Mono
      Project Audio Format: 44100 Hz - 32 bit floating point - Mono
      Total Duration: 03:29:38:14
      Average Data Rate: 11 KB / second
      Pixel Aspect Ratio: 1.0
      Source Audio -
      Type: MP3 Audio
      File Size: 133.8 MB
      Source Audio Format: 44100 Hz - compressed - Stereo
      Project Audio Format: 44100 Hz - 32 bit floating point - Stereo
      Total Duration: 01:37:32:38160
      Average Data Rate: 23 KB / second
      Export -
      H.264 / Vimeo HD / 44.1, High Quality, AAC, Stereo
      1 minute of source export benchmarking:
      Set Mercury Playback to NO-GPU/Delete Render Files/Render Entire Work Area/Export = 32 seconds
      Set Mercury Playback to GPU/Delete Render Files/Render Entire Work Area/Export = 113 seconds
      I also noted that, with BIOS hyperthreading ON, GPU=On results in the 8 hyperthreads having no activity.
      IDK
      Please help...
