2 Replies Latest reply on Apr 16, 2013 5:19 AM by Janaaaaa
    Export panel automatic export button click applescript
    Janaaaaa
      HI.
      Is there any way to click Indesign export button in  export pdf panel with applescript
      I am doing applescrict to export pdf:s and I can not use in code printing option ( without showing options) cause
      sometimes some elements wont print  to final pdf. and that is problem also all commercial programs when background printing is enabled.
      So I try build script with showing options but I can not automatically click that export button.
      I tried this one but it does nothing.
                tell application "System Events" to tell process "Adobe InDesign CS5.5"
        key code 36
                          end tell
      This is my hole script so far under construction
      tell application "Finder"
                if not (exists folder "myFolder") then
        make new folder at desktop with properties {name:"myFolder"}
                end if
      end tell
                set myfiles to the selection
      end tell
      tell application "Adobe InDesign CS5.5"
        activate
                repeat with i in myfiles
                          open (i as alias)
                          set thePreset to "[Smallest File Size]"
                          set theDesk to (path to desktop as string) & "myFolder:"
                          set f to (name of i as string)
                          set thepath to theDesk & f
        delay 2
        export document 1 to file (thepath & ".pdf") format PDF type using PDF export preset thePreset with showing options
        key code 36
                          end tell
        close active document saving no
                end repeat
      end tell
      Thanks if someone have Idea
        • 1. Re: Export panel automatic export button click applescript
          Muppet Mark Level 5
          Well personally I think you should look to resolving your issues in other ways… I don't really see where calling up the GUI dialog fixes things… Anyhows that aside this does force a keystoke when required…
                    end if
          end tell
          tell application "Adobe InDesign CS5"
            activate
                              open (i as alias)
                              with timeout of 5 seconds
                                        try
            export document 1 to file (thepath & ".pdf") format PDF type ¬
                                        on error
                                                  my keyStroker()
                                        end try
                              end timeout
                    end repeat
          end tell
          on keyStroker()
                    tell application "System Events" to tell process "Adobe InDesign CS5" to keystroke return
          end keyStroker
          • 2. Re: Export panel automatic export button click applescript
            Janaaaaa Level 1
            Thank you very much Muppet Mark. You are great.
            Now I can go home and leave exporting running on evening.
            Yes this might be not greatest way exporting but I can be sure that every elemenet is showing in final pdf.
            and only way I can figure this out is this way.
            I have to develop this little more to print individual pages from indesign and ignoring overset text and something else.
            I think that we have so many different graphics and raster images with different file types that something goes sometimes wrong
            when exporting to pdf version 1.3 and  rasterizing and flattening is going on.
            Callig GUI seems to do the job. at least 50 pdf exported right.
            Thanks.
