2 Replies Latest reply on Apr 16, 2013 10:21 PM by nitzan gertz
    combine 2 photos as layers
    nitzan gertz
      Hello
      I know how to combine photos as layers.
      However, I would like to delete some ares from one of the layers, and merge it with the first layer to one photo.
      I used the brush tool, both black and white color, but all I get is black/white spots on each layer I use.
      Can't I merge them to one photo, deleting the areas I would like to?
      Thanks a lot
      Nitzan Gertz
      LG Nexus4 with Photoshop touch.
        • 1. Re: combine 2 photos as layers
          janelle_f Adobe Employee
          Hello there-
          It seems like you want to make a photo Composite. To start off there is a great PS Touch for Tablet tutorial here.
          1. Below you can see I have two photos I would like to merge into "one". I selected an eraser tool to erase portion of the image I have selected. I will only need the woman's head, so erasing it is a great way to eliminate a portion of the painting.
          2. Below you can see how I have just the woman's head remaining from the top layer. The painting below reveals the woman's hat, which I will next want to remove.
          3. I am going to transform the size of the woman's head, by tapping the outlined tool.
          4. Below I have changed the size of the woman's head. Tap the checkmark when you are done.
          5. I am not going to eliminate the bottom layers woman's hat. By tapping the clone tool, I can clone the surrounding area to eliminate the hat.
          6. Below you can see the woman's hat is now removed.
          7. Now I am going to merge the layers. Tap the top layer, then the layer icon and tap the "merge" icon.
          8. Select Merge Down > Done.
          9. You now have created a composite.
          Please let us know if you have any questions.
          Janelle
          • 2. Re: combine 2 photos as layers
            nitzan gertz Level 1
            Thanks a lot for your quick and excellent very detailed answer!
