3 Replies Latest reply on Apr 18, 2013 10:12 PM by Flex harUI
    When I change state the UI does not update
    jwebb-compunetix Level 1
      I have some code that uses state changes to manage the buttons in a login screen:
              <mx:states>
                      <!-- Default state: the LoginWindow accepts input from the user -->
                      <!--  Login
                              login is in progress.
                              No input allowed other than the "Cancel" button
                      <mx:State name="{STATE_LOGIN}">
                              <mx:SetProperty target="{loginForm}" name="enabled" value="false"/>
                              <mx:SetProperty target="{loginButton}" name="enabled" value="false"/>
                              <mx:SetProperty target="{cancelLoginButton}" name="enabled" value="true"/>
                              <mx:SetProperty target="{statusLabel}" name="text"
                                                              value="{resourceManager.getString(ResourceNames.BUNDLE_NAME,
                                                              ResourceNames.LOGIN_CONNECTING_STATE)}"/>
                      </mx:State>
      The problem is that when I change the state by setting currentState to STATE_LOGIN the UI change does not happen right away. In fact it doesn't take place until the login event is complete, creating a race condition.
      However, I've been able to work around this problem by explicitly setting the values of loginButton.enabled and cancelLoginButton.enabled in my program:
                loginButton.enabled = false;
                cancelLoginButton.enabled = true;
      When I do this, the buttons are enabled in the right way.
      Why does explicitly setting the button enabled flags work, but the state change, which should do the same thing, not?
