3 Replies Latest reply on Apr 17, 2013 12:16 AM by Rick Gerard
    Possible to easily cut the compilation length?
    Level 1
      I thought that Media Encoder took forever to export my stuff... then I realized it had continued waaaaaaaaay beyond the actual size of the composition (as determined by the bar in Ae), and continued for the full duration which was much longer than that bar. Since trying to tell it to use only the bar in Media Encoder is a huge chore, can I somehow easily "cut to the bar" in Ae with a couple of clicks or so?
      In order to make the composition LONGER, you apparently *must* edit the compo settings and manually enter a value. However, I'm hoping there is an easy way to cut it down to only the length it actually turns out to be when you are done. It would solve this problem and also make it more pleasant to navigate.
