5 Replies Latest reply on Apr 17, 2013 8:43 AM by shilpa25
    Place assets only on First page
    shilpa25
      Hi Forum,
      I m wondering, if can i place my Library assets.item(0) only on first page.
      Because the below script places the Library assets, when i click a particular page...
      Instead, when i run the script, the assets should be placed only on the first page..
      Is it possible... I tried this way.. but doesnt works...
      pg = app.activeDocument.pages.item(0);
      //myrect = pg.rectangles.add(); (i tested with adding rectangles on the first page, it works)
      var Lib = app.libraries[0].assets[0].placeAsset[pg][0];
      thanks for the help forum...
      Shil..
        • 1. Re: Place assets only on First page
          -hans- Level 4
          onDocument
          Text
          Those are the possibilties.
          So only a trick would work:
          Create a empty textframe on destpage and place the asset on its insertionpoints[0].
          Then set anchored objectsettings to customized (x,y to textframe top/ left zero).
          detach the anchored object. Delete the textframe.
          otherwise conventionell:
          move the object after placing on document to any page.
          • 2. Re: Place assets only on First page
            shilpa25 Level 1
            hi -hans- thanks very much for your quick response.....
            will moving the object placed to any page is possible. because i have a little bit confusing on selecting the placed object (if is the grouped text) alongwith the other text boxes on the same page.
            how can i refer the placed object in script.
            sorry for the confused state of question....
            thanks for the reply.
            shil....
            • 3. Re: Place assets only on First page
              shilpa25 Level 1
              hi -hans-
              thanks for you brilliant idea...
              now, i have tried like this...
              var myObj = app.libraries[0].assets[0].placeAsset(app.documents[0])[0];
              app.select(myObj);
              app.selection[0].move (app.activeDocument.pages[0]);
              ( it would be appreciate, if i get idea for delesecting the previous selected items and then select the corrently placed one).
              thanks - hans-
              • 4. Re: Place assets only on First page
                -hans- Level 4
                no need to select as you've already stored the obj in myObj
                var currDoc = app.activeDocument;
                var myObj = app.libraries[0].assets[0].placeAsset(currDoc)[0];
                myObj.move(currDoc.pages[0]);
                • 5. Re: Place assets only on First page
                  shilpa25 Level 1
                  thank you -hans-,
                  you have simplified my complex script.
