1. Re: Can anyone explain this David Blatner tip?
P Spier Apr 17, 2013 2:26 AM (in response to katernya)Select one frame first, and make your size adjustments.
Now select the other frames you want to match (select the first, then hold shift while selecting the others, or drag a marquee selection arcross multiple frames), and you shoue see the transform again choices.
2. Re: Can anyone explain this David Blatner tip?
katernya Apr 17, 2013 2:37 AM (in response to P Spier)Yes I have done that but the ‘Transform Again’ choices are grayed out. Does it work for you?
3. Re: Can anyone explain this David Blatner tip?
katernya Apr 17, 2013 2:40 AM (in response to katernya)I see. The trick is you have to alter the size of the first frame. I was just trying it with 3 different sized frames that I had placed on the page.
4. Re: Can anyone explain this David Blatner tip?
P Spier Apr 17, 2013 2:41 AM (in response to katernya)Yes. Try trashing your prefs. See Replace Your Preferences
5. Re: Can anyone explain this David Blatner tip?
P Spier Apr 17, 2013 2:42 AM (in response to P Spier)Sorry -- typing while you were posting. No need to do the prefs.
Yes, if you haven't performed a transformation, there's nothing to transform again.
6. Re: Can anyone explain this David Blatner tip?
katernya Apr 17, 2013 2:47 AM (in response to P Spier)Thanks Peter. You do a great job on these forums with politeness and expertise.
