4 Replies Latest reply on Apr 17, 2013 12:22 PM by JimmyRun
    Threading text that's not the same size
    JimmyRun
      I prepare files for a magazine and I have an ongoing problem and I hope someone has a solution.
      When the text of a feature story is too long, we continue the story in the back of the issue. The text of the bulk of the story is 10pt while the text at the back of the isuue is 8pt.
      For instance say I have a 7 page INDD file and all of the text is threaded. I want page 1-6 to be 10pt text but page 7 would be 8pt text.
      Is there a way in INDD to make the text automatically change size based on the page or text box that it flows through?
        • 1. Re: Threading text that's not the same size
          TᴀW Adobe Community Professional & MVP
          Well, that's an interesting question.
          My instinct at first was, "For sure not!" Maybe in Illustrator, by
          adding a live effect to reduce the page or something.
          But then, hey, what do you know! It IS possible, very easily, in InDesign.
          Let's say you've got 3 connected text frames, X, Y, and Z, and you want
          the text in Z to be automatically smaller.
          Easy! Select frame Z. Pressing control-shift, drag one the corners to
          resize the frame. You will see that the text reduces in size as well,
          proportionally. But of course, text frame Z is now quite small. How do
          you get it back to size, while keeping the text inside small?
          Also easy: without pressing control-shift, simply drag the same corner
          of text frame Z back to the size you want, and that's it. The text frame
          will be the same size as before, but the text inside will be smaller.
          Ariel
          • 2. Re: Threading text that's not the same size
            @Jimmy – yes.
            And you can get it without scripting!
            1. Go to the Preferences
            2. Set Scaling to "Adjust Scaling Percentage"
            3. Go to page 7 and scale all the text frames to 80%
            4. Adjust the width and height of the scaled text frames to their original dimensions WITHOUT scaling. E.g. by mouse…
            That simple.
            The text flows through all the threaded text frames on pages 1 - 6 unscaled and will be scaled from 10pt to 8pt (80%) on
            page 7. If you select text in scaled text frames you'll see the value "10 Pt(8)". You could use the baseline grid of the scaled text frames for further adjustment of the leading.
            Do not forget to change the prefernces to there original setting, if you completed the scaling of the text frames.
            Uwe
            Message was edited by: Laubender
            • 3. Re: Threading text that's not the same size
              JimmyRun Level 1
              Thanks Laubender! I tested it and it works!
              • 4. Re: Threading text that's not the same size
                JimmyRun Level 1
                Thanks Ariel. It works!
