0 Replies Latest reply on Apr 18, 2013 5:09 AM by anjemalo
    Slider images with ease
    anjemalo Level 1
      Hello:
      I'm using the "HorizontalImageSlider.Behaviour" get it from www.lingoworkshop.com on the Slider_tut.dir file.
      I have to try to get easing effect with this but I dónt know where to put the code for this and what code is.
      I have commented on Enterframe the part where is the slide, only for drag.
      Can you help me please?
      Thank you very much.
      This is the code:
      property ancestor
      property myMidH, myShift, myAlpha, myOffset
      property myTrackingFlag, myStartH
      property mySlideLeftRect, mySlideRightRect
      on beginSprite me
          thisSprite = sprite(me.spriteNum)
        thisRect = thisSprite.rect
        thisMember = thisSprite.member
        thisCanvas = thisMember.image
        thisCanvas.fill(thisCanvas.rect, rgb("#000000"))
        myOffset = point(thisRect.left, thisRect.top)
        myMidH = thisSprite.left + (thisSprite.width/2)
          -- get a list on images to show
        fndImages = me._GetImages()
          -- create the slider object
        ancestor = script("HorizontalImageSlider.Class").new()
        me.Initialise(thisCanvas, thisCanvas.rect)
        me.LoadImages(fndImages)
          -- create the 'hot spots' for sliding
        mySlideLeftRect = rect(thisSprite.left, thisSprite.top, thisSprite.left + (thisSprite.width/3), thisSprite.bottom)
        mySlideRightRect = rect(thisSprite.right-(thisSprite.width/3), thisSprite.top, thisSprite.right, thisSprite.bottom)
      end
      on endSprite (me)
        -- clean up the canvas
      end
      on enterframe (me)
        if myTrackingFlag then
          -- the mouse was clicked on this sprite
          if not (the mouseDown) then
            -- stop tracking
            ----------------------------------------------------- myTrackingFlag = 0
          else
            -- 'drag' the slider to the current mouse location
            mH = the mouseH
            amt = myStartH - mH
            myStartH = mH
            me.Slide(amt)
          end if
        else
          p = the mouseLoc
          if inside(p, mySlideLeftRect) then
            -------------------------------------------------------------I remove this code only need Drag
            --------------------------      proposedAmt =  myShift -1
            --------------------------      myShift = Max(-50, proposedAmt)
            --------------------------   else  if inside(p, mySlideRightRect) then
            --------------------------      proposedAmt =  myShift + 1
            --------------------------      myShift = Min(50, proposedAmt)
          else
            -- slow down to a stop
            myShift = myShift * 0.75
            if abs(myShift) < 2 then myShift = 0
          end if
          me.Slide(myShift)
        end if
      end
      on mouseDown (me)
        ClickedTile = me.GetTileAtPoint(the mouseLoc - myOffset)
        if voidP(ClickedTile) then return
        myTrackingFlag = 1
        myShift= 0
        myStartH = the mouseH
        me.SelectTile(ClickedTile, (the shiftDown))
        PUT ""& ClickedTile   --AML
      end
      on _GetImages (me)
        fnd = []
        mx = (the number of members of castlib "Images")
        repeat with i = 1 to mx
          m = member(i, "Images")
          fnd.append(m)
        end repeat
        return fnd
      end
