I am using Coldfusion 9.0 and have downloaded the required files CF9.zip and CFIDE-9.zip and extracted them. I cannot find the file 'WEB-INF.zip' file in the CF9 directory referenced in the instructions. The only update file in the CF9 directory is 'hf900-00010.jar'. Where can I get this file? I don't know if I can proceed without it. I'm partly through the fix and am now concerned about any reboot without fully completing the fix.
Thank you. Subsequently, I did find corrected instructions for CF 9.0.2 and hoped the same was true for 9.0.0.
Thank you for your reply confirming that.
You don't need the WB-INF.zip to be updated. You only need to update the jar file from CF9/lib/updates and the Extract all the files in CFIDE-9.zip to merge in the web root directory that has {CFIDE-HOME} directory. If you follow the instructions step by step, you should not face any issue.
Regards,
Anit Kumar
