1 Reply Latest reply on Aug 3, 2006 6:10 AM by Newsgroup_User
    Problem with Fireworks Navigation
    k_sonia
      Hi All,
      I designed a navigation bar in fireworks and export the file (s)..The navigation bar (www.9dcateringhk.com/menu.php)is working fine if I use graphic (Jpg or gif) image in next row..(Means I can see drop down stuff If I insert simple graphic in next row) However, The drop down hides (www.9dcateringhk.com/gallery.php) if I insert Flash (.fla , .swf or <iframe> ) into next row.
      Please help me to fix this problem... I really need to do this..
      Please send me all the replies at s_khurmi@hotmail.com
        • 1. Re: Problem with Fireworks Navigation
          Level 7
          k_sonia wrote:
          > Hi All,
          > into next row.
          Here is a TechNote about why "Pop-up Menus appear behind active content"
          < http://www.macromedia.com/go/15842>.
          This particular document explains why pop-up menus appear behind active
          contents such as Flash movies. It also gives some suggestion on how you
          can prevent this from happening.
          Though it doesn't work for all browsers in all circumstances, setting
          the wmode to opaque will allow you to have the menus appear over the
          Flash movie in some browsers:
          <PARAM NAME=wmode VALUE=opaque>
          There is a Flash TechNote on this:
          < http://www.macromedia.com/support/flash/ts/documents/flash_top_layer.htm>
          Linda Rathgeber [PVII] **Adobe Community Expert-Fireworks**
          http://www.projectseven.com
          Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
          CSS Newsgroup: news://forums.projectseven.com/css/
          Design Aid Kits: http://www.webdevbiz.com/pwf/index.cfm
