1 Reply Latest reply on May 6, 2013 6:40 AM by AceMcKilty
    Trouble Importing Sony Vegas AAF
    AceMcKilty
      My apologies if this was covered somewhere-- I did search...
      I have some Sony Vegas 10 projects which I exported as AAF files.  Sony has two AAF Save As Types:
      • Edit Protocol Compliant  AFF File
      • Avid Legacy AFF File
      I have not noticed any difference in the results of importing them.
      I open Premiere Pro CS6 (Version 6.0.2 (072 (MC: 264587)) Mighty Kilt and choose Import.  I navigate to the AFF files I created in Vegas and import it.
      First, I get a log of how it could not be completed fully (see Import Log below).  The issues are related to audio transitions and I'm not worried about that.  Then it imports the files which then appear in the Project Pane in it's own bin.
      My issue is that nothing appears in the sequence timeline.  What does the import actually do-- take note of what files I used?  I expected all of the tracks to be created and populated with the audio and video files.
      Thanks for your help!
      Rick
      EDIT: I exported a EDL from vegas and renamed it to EDL so it could be imported (Premiere would not import the original .txt file).  I imporeted this into Premiere and I was prompted for NTSC versus PAL and then project settings.  I still don't see anything in Premiere after doing this.
      IMPORT LOG
      The AAF file "/Users/rickbray/Desktop/Bio_Song_9.aaf" could not be imported completely and/or accurately, as logged below:
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 16412, Time: 00:09:07:02) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 21680, Time: 00:12:02:20) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 22973, Time: 00:12:45:23) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 23711, Time: 00:13:10:11) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 26598, Time: 00:14:46:18) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 27825, Time: 00:15:27:15) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 32107, Time: 00:17:50:07) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 33036, Time: 00:18:21:06) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 34042, Time: 00:18:54:22) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 37741, Time: 00:20:58:01) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 42284, Time: 00:23:29:14) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 45266, Time: 00:25:08:26) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 46888, Time: 00:26:02:28) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 48955, Time: 00:27:11:25) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 52060, Time: 00:28:55:10) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 68371, Time: 00:37:59:01) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 68661, Time: 00:38:08:21) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 1, Position: 69038, Time: 00:38:21:08) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 971, Time: 00:00:32:11) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 3324, Time: 00:01:50:24) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 4705, Time: 00:02:36:25) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 4729, Time: 00:02:37:19) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 5435, Time: 00:03:01:05) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 8099, Time: 00:04:29:29) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 8175, Time: 00:04:32:15) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 13135, Time: 00:07:17:25) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 14798, Time: 00:08:13:08) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 14915, Time: 00:08:17:05) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 16246, Time: 00:09:01:16) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 19949, Time: 00:11:04:29) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 23806, Time: 00:13:13:16) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 26524, Time: 00:14:44:04) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 27907, Time: 00:15:30:07) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 29901, Time: 00:16:36:21) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 29960, Time: 00:16:38:20) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 31962, Time: 00:17:45:12) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 32096, Time: 00:17:49:26) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 33124, Time: 00:18:24:04) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 34014, Time: 00:18:53:24) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 37813, Time: 00:21:00:13) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 40012, Time: 00:22:13:22) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 41609, Time: 00:23:06:29) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 42278, Time: 00:23:29:08) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 44328, Time: 00:24:37:18) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 45242, Time: 00:25:08:02) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 47004, Time: 00:26:06:24) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 48825, Time: 00:27:07:15) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 51189, Time: 00:28:26:09) because it is not supported. Transition was ignored.
      Cannot import audio transition "Mono Audio Dissolve" (Sequence: "Bio_Song_9", Audio Track: 2, Position: 51923, Time: 00:28:50:23) because it is not supported. Transition was ignored.
