4 Replies Latest reply on Oct 29, 2007 10:58 AM by Newsgroup_User
    Memory Leaks in AS2
    Level 7
      Hey folks,
      I am working on some *AS2* code.
      Problem: Basically, I'm loading my SWF file in Firefox; and the memory
      used is going upwards nonstop. After a couple of minutes, all system
      resources are used and I need to restart the browser. I suspect
      (obviously) a memory leak or the garbage collection not doing its proper
      job.
      Question: Is there some tools I can use to diagnose this problem and
      retrace where the leak is coming from. Ultimately is there some garbage
      collection optimization I should be aware of?
        • 1. Re: Memory Leaks in AS2
          Level 7
          How are you loading your clip? This pretty much has to be a problem with how
          you're doing it, otherwise this problem would appear all the time- and it
          doesn't.
          Dave -
          Head Developer
          http://www.blurredistinction.com
          Adobe Community Expert
          http://www.adobe.com/communities/experts/
          • 2. Re: Memory Leaks in AS2
            Level 7
            On Sun, 28 Oct 2007 11:11:31 -0500, DMennenoh **AdobeCommunityExpert**
            > how you're doing it, otherwise this problem would appear all the time-
            > and it doesn't.
            Hmm, I haven't looked at that approach; maybe something messing up here.
            I'm loading the SWF through JavaScript using the "SWFObject v1.4.4: Flash
            Player detection and embed"; looks similar to the following:
            <div id='object-content'></div>
            <script type='text/javascript'>
            theObject = new SWFObject("object.swf", "uid", "100%", "100%", "7",
            "#FFFFFF", false, "high", null, "noflash.html");
            theObject.addParam("param_1", "default");
            theObject.addVariable('var_1', "some value");
            theObject.write("object-content");
            </script>
            • 3. Re: Memory Leaks in AS2
              you have some kind of endless loop. are you repeatedly trying to load something (like a load statement that repeatedly executes)? are you using a loop of some kind (like a preloader)?
              • 4. Re: Memory Leaks in AS2
                Level 7
                On Sun, 28 Oct 2007 04:04:44 +0000, Michel B wrote:
                > Hey folks,
                > job.
                > Thanks
                I have an update. It turns out the memory is leaking ONLY one of my
                machines (which is running Ubuntu Gutsy Gibbon 7.10). I am running the
                latest version of Flash 9.0.48. I tried the SWF on Windows and other
                flavors of Linux, and it works fine there.
                Anyone encountered the same problem?
