So, I have just downloaded the New Acrobat XI, which I only need for Distiller anyway and have no other use for at all
When i launch Distiller it pops up, then its gone
I Uninstalled all of my Fonts but the System Fonts
I went to Safe Mode and Deleted all of the System Fonts I could, then I Overwrote the existing ones with a Fresh Set of System Fonts.
Still same problem
Tried Uninstalling & Reinstalling, to No Avail
Illustrator works Fine, Photoshop works Fine, InDesign Works Fine, Acrobat XI Works Fine
No program on my system has even the slightest bit of Font problem..
My Font Manager has said my Fonts are all Green
I Uninstalled XI and Installed Acrobat 9 Pro, and Distiller Worked perfectly
I think it has to do with one of the following:
C:\Windows\Fonts
C:\Program Files (x86)\Common Files\Adobe\Fonts
C:\Program Files (x86)\Common Files\Adobe\Sing Mark II
C:\Program Files (x86)\Common Files\Microsoft Shared\EQUATION
D:\Program Files (x86)\Acrobat\Acrotabt 11\Resources\Font
So here are my questions:
thanks
nobody has any idea about what this problem might be?
even the slightest direction would be helpful
thanks
It appears you are running a 64-bit system. I suspect it is probably Win7, but you did not say. My guess is that you are still running AA XI.0.0. You should open Acrobat and go to help>updates. If that does not work, let us know so we can help in the download of updates.
thanks for the reply.
I updated to 11.0.1, according to the Update Site
I am running Windows 7 Ultimate x64.. I think thats standard, there arent many people using 32-bit Windows who do much Graphic work, since its limited to 3.5GB of Ram..
and Windows 7 is still the Workhorse of the Windows Family, not to be replaced by 8 for most Office & Pro Desktop Publishing Solutions..
so, if something isnt working with Windows 7 x64 it basically has a problem with Windows altogether, these days
anyway, I really thought it might work.. but it didnt.. thanks though.. any other ideas??
went to a Log in C:\Users\username\AppData\Roaming\Adobe\Acrobat\Distiller 11
and at the bottom, under the date of everytime i tried to launch Distiller, I get this same log:
Adobe PostScript software version: 3018.101
CID support library initialization completed.
Adobe PDF Settings file read error in PDFX4 2008.joboptions:
/CheckCompliance out of range
I tried Renaming the PDFX4 2008.joboptions file at C:\ProgramData\Adobe\Adobe PDF\Settings, but that didnt fix it..
I searched for "checkcompliance" in PDFX4 2008.joboptions, and there was only one entry, this:
/AllowPSXObjects false
/CheckCompliance [
/PDFX4:2007
/PDFX1aCheck false
/PDFX3Check false
/PDFXCompliantPDFOnly true
/PDFXNoTrimBoxError false
/PDFXTrimBoxToMediaBoxOffset [
0.00000
0.00000
0.00000
0.00000
I tried Deleting CheckCompliance[/PDFX4:2007] but that didnt work , and no changes were made to the log
I tried adding the line /PDFX4Check false, but that also had no effect and no log entry
Also, when I double-click on the PDFX4 2008.joboptions file, it opens the Preferences, but I dont see anything in there that would help
Anyone have any ideas?
thanks
I tried putting an old PDFX42008 file i had backed up from a previous Acrobat.. but that wasnt able to open when double-clicked.. so I put the original back as it was, and it made different log entry when trying to run:
which seems a success to me, but the behavior was the same.. shows a splash screen, shows the program for about 1 second, then closes completely..
so I dont know what to make of this
Well, it seems to be the result of a System Modification preventing Programs from accessing different DLL's in certain ways, if certain behaviors are present, which is what the Trial Version of Acrobat does, Spamming that Pop-up Screen everytime Distiller is open, After its been open.. it then reaches for its Spam message, which is where it was blocked.. which Distiller responded to by closing
I think this is malicious behavior..
Programmed by Adobe, Acrobat doesnt have the same spam, only Distiller, why would Acrobat not have it, but poor Distiller, of all things, have it?
is it that you dont think anyone important uses Distiller, and so you'll spam the crap out of them?
Its a Malicious & Suspicious behavior.
Another little purposely-programmed Malevolence on the Part of Adobe which resembles much bigger problems causing users to spend days or weeks trying to fix the problem, and invest a considerable amount of resources, money, & time to attempt to repair..
and all the while, its adobes ultimate plan all along..
its almost as good as the Multiple-Scratch Disks errors that made me want to go out and replace my entire computer.
thanks again Adobe..
So, to Recap on this Problem:
Possible Cause 1:
Corrupt Fonts
Too Many Fonts
Solutions:
Possible Cause 2:
Adobe Spam Advertisement to Buy throughout "Trial" Versions - Spam Launcher Blocked
Solutions:
The Term "Trial" is quite Accurate, its very aptly named.. Getting it to work right is quite the crucible
"Trial By Fire & Brimstone" might be an even more clarifying & better-suited name
Hi there,
I have the same Distiller crash problems and suspect it has something to do with my Fonts. I thought I deleted all not-original fonts but maybe there's one left. I tried using the Font Validator, but it took ages and finally crashed somewhere at font 37 of 100+. Do you maybe have a link to a free fault manager that you mentioned? I've been stuck at this problem for a while now, it used to work just fine but now it just keeps crashing and I need the Distiller for my business.
Thanks in advance.
Here is My List of the Best Free Font Management Software (In Alphabetical Order😞
I cant remember which of these have Font Testers, or which can Load/Unload:
Adobe Type Manager with Adobe Type Manager Fix
I think These have Most Potential:
Nexus Font
Font Matrix
AMP Font Viewer
Opcion
CFont Pro
Font Xplorer Free
Also,
CG Font Load Unload from CGrech is a small, portable tool that allows you to Temporarily Load & Unload Fonts to use with programs, without Installing & Uninstalling them.. great to use with any fonts other thn system fonts..
And if you're into paid Font Managers:
Here is my List of the Best Paid Font Management Software (Not Free - In Order of Best):
Suitcase Fusion
Font Agent Pro (maybe No Windows 7 or 8 support yet)
Font Expert
Printer's Apprentice
MainType
Advanced Font Viewer
I personally use Font Expert.. but I'd like to try some of the other ones
And Here's How I used Microsoft Font Validator:
Since its Easy to have some Font Problems with newer versions of certain programs like Adobe Distiller Illustrator, Photoshop, InDesign, etc... which have stricter requirements for Font Integrity prior to program launch, Here are some measures I took to build up & Maintain the Integrity of my Font Collection:
Clean up Files:
Also, you can try booting into safemode, and replacing all the system fonts you are able to with Known Good Original Fonts, such as from a diffferent computer with a newer Install, or download them from a Windows Font Restore Collection online, etc..
Of course, i did all of this and more, and didnt even need to.. thanks to the Cheeky Adobe Team, skilled in the black arts of making your computer appear to have problems it doesnt...
Wow what a quick and immense answer! Thank you very much.
So you're basicly saying that I'm probably going to do all these tests and possible solutions for nothing because it could just as well just be the black arts of Adobe playing and I'm just better off with for example acrobat 9? Don't the forums flush over with Distiller problems with other Distiller versions as well? Sadly you can't just switch to an other Distiller version can you? Because I like the Acrobat XI, it's only the Distiller that is causing the isssue.
right..
i likewise was quite enjoying Acrobat XI.. I've since gone back to an older version, just because of how Adobe deals with the Distiller users
Acrobat users would certainly not tolerate this sort of harassing behavior, but Distiller users are only a small percent of the Acrobat user-base, so their manipulations & abuses can go unnoticed, and unvoiced.
I refuse to purchase any program who's trial is so offensive as Distillers.. or who's programming seems willfully undermining of the Users Liberties, Uses, and Enjoyment
So bon voyage XI
LOL, so which version do you recommend?
I didnt like X at all..
the last good one was 9.. didnt like 8 either.. but 7 was nice too..
I am having the same issue on a MAC.
I have completely removed all fonts, I have used Font Doctor and Suitcase Fusion 5 to remove any font issues. I am running OS 10.8.5. Adobe CC Abrobat Pro 11. Here is what my results are every time I try to load our company-specific joboptions file. I even have a BRAND NEW hard drive as of 2 weeks ago. I have read every forum and have experienced every issue that you have had but no fix has worked. Have you had any success yet?
Process: | Distiller [1028] |
Path: | /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/MacOS/Distiller |
Identifier: | com.adobe.distiller |
Version: | 11.0.0 (11.0.0) |
Code Type: | X86 (Native) |
Parent Process: launchd [149]
User ID: | 502 |
Date/Time: | 2013-12-04 12:06:22.593 -0600 |
OS Version: | Mac OS X 10.8.5 (12F45) |
Report Version: 10
Interval Since Last Report: | 13918 sec |
Crashes Since Last Report: | 4 |
Per-App Interval Since Last Report: 12 sec
Per-App Crashes Since Last Report: 3
Anonymous UUID: | 28662061-274B-952D-6AFF-629684E39252 |
Crashed Thread: 12
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
[1028] stack overflow
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib | 0x972127ce mach_msg_trap + 10 | |
1 libsystem_kernel.dylib | 0x97211cac mach_msg + 68 | |
2 com.apple.CoreServices.CarbonCore | 0x93dcc003 YieldToThread + 389 | |
3 com.apple.CoreServices.CarbonCore | 0x93dcc252 YieldToAnyThread + 18 | |
4 com.adobe.DistillerLib | 0x015e9ae3 DistillerYield + 83 | |
5 com.adobe.DistillerLib | 0x015d86f5 DistillerEngine::Init() + 1093 | |
6 com.adobe.DistillerLib | 0x015e8110 DistillerOpen + 48 | |
7 com.adobe.distiller | 0x0002a182 DistLibStartDistiller() + 194 | |
8 com.adobe.distiller | 0x00004bca -[AADAppController awakeFromNib] + 922 | |
9 libobjc.A.dylib | 0x92cbf586 -[NSObject performSelector:] + 62 | |
10 com.apple.CoreFoundation | 0x9834c5b4 -[NSSet makeObjectsPerformSelector:] + 228 | |
11 com.apple.AppKit | 0x961dff11 -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1180 | |
12 com.apple.AppKit | 0x966aa14c old_loadNib + 349 | |
13 com.apple.AppKit | 0x961bdb0c +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 939 | |
14 com.apple.AppKit | 0x9630e8a4 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 154 | |
15 com.apple.AppKit | 0x961bd51f +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 709 | |
16 com.apple.AppKit | 0x961b9398 NSApplicationMain + 447 | |
17 com.adobe.distiller | 0x00002635 start + 53 |
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib | 0x972159ae kevent + 10 | |
1 libdispatch.dylib | 0x9488fc71 _dispatch_mgr_invoke + 993 | |
2 libdispatch.dylib | 0x9488f7a9 _dispatch_mgr_thread + 53 |
Thread 2:
0 libsystem_kernel.dylib | 0x972150ee __workq_kernreturn + 10 | |
1 libsystem_c.dylib | 0x949810ac _pthread_workq_return + 45 | |
2 libsystem_c.dylib | 0x94980e79 _pthread_wqthread + 448 | |
3 libsystem_c.dylib | 0x94968daa start_wqthread + 30 |
Thread 3:
Thread 4:
Thread 5:
0 libsystem_kernel.dylib | 0x972148e2 __psynch_cvwait + 10 | |
1 libsystem_c.dylib | 0x94983280 _pthread_cond_wait + 833 | |
2 libsystem_c.dylib | 0x94a09089 pthread_cond_wait$UNIX2003 + 71 | |
3 com.apple.CoreServices.CarbonCore | 0x93dce492 TSWaitOnCondition + 128 | |
4 com.apple.CoreServices.CarbonCore | 0x93dce68e TSWaitOnConditionTimedRelative + 146 | |
5 com.apple.CoreServices.CarbonCore | 0x93d1aacb MPWaitOnQueue + 261 | |
6 com.adobe.ACE | 0x012e04dc ACEMPThread::Task() + 126 | |
7 com.adobe.ACE | 0x012e0441 TaskGlue + 17 | |
8 com.apple.CoreServices.CarbonCore | 0x93da1a7b PrivateMPEntryPoint + 68 | |
9 libsystem_c.dylib | 0x9497e5b7 _pthread_start + 344 | |
10 libsystem_c.dylib | 0x94968dce thread_start + 34 |
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12 Crashed:
0 libsystem_kernel.dylib | 0x97214a6a __pthread_kill + 10 | |
1 libsystem_c.dylib | 0x9497fb2f pthread_kill + 101 | |
2 libsystem_c.dylib | 0x949b6738 __abort + 199 | |
3 libsystem_c.dylib | 0x949b8b5e __stack_chk_fail + 233 | |
4 com.adobe.DistillerLib | 0x018e11d9 ReadCFFIndex + 585 | |
5 com.adobe.PDFL | 0x00544c46 0x53000 + 5184582 |
Thread 12 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x66666667 ecx: 0xb063b0dc edx: 0x97214a6a
edi: 0xb063c000 esi: 0x00000006 ebp: 0xb063b0f8 esp: 0xb063b0dc
ss: 0x00000023 efl: 0x00000206 eip: 0x97214a6a cs: 0x0000000b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x037fb000
Logical CPU: 0
Binary Images:
0x1000 - | 0x33ff3 +com.adobe.distiller (11.0.0 - 11.0.0) <EDB6DDE1-ABB4-3469-ADEA-B3DA00DB1102> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/MacOS/Distiller |
0x53000 - 0x825fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 11.0.0.21186) <44FE792C-B542-37E0-88B7-C74F7D4CAB5C> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
0x8b5000 - 0x8d6ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.21186 - 3.7.101.21186) <D65C0C81-572E-3DCB-A1CF-BC5BF2D59500> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x8f5000 - 0xec9ff7 +com.adobe.AGM (AdobeAGM 4.28.32.1 - 4.28.32.1) <4E17E364-9586-3654-A1EB-C8AB66C351EE> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x12de000 - 0x1430fe7 +com.adobe.ACE (AdobeACE 2.20.02.1 - 2.20.02.1) <711209D4-FBA8-37AE-9B21-E7F7EAE52A36> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x14a6000 - 0x14e0ff3 +com.adobe.ARE (AdobeARE 1.5.02.21195 - 1.5.02.21195) <583E0BDD-2204-3470-BDEB-330B4EE311F3> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x14e7000 - 0x1505ff3 +com.adobe.BIB (AdobeBIB 1.2.03.1 - 1.2.03.1) <21A36908-3031-35AF-A74B-ECC65BEAEC9F> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x152c000 - 0x1552ffb +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <DE33E3BF-669D-3851-8C16-CA1CFCDA315A> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x1559000 - 0x15afffb +com.adobe.AdobeXMPCore (Adobe XMP Core 5.4 -c 5 - 78.147326) <82EFE343-F643-34AD-94FA-293E338F1F9C> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x15b8000 - 0x1a1cfff +com.adobe.DistillerLib (11.0.0 - 11.0.0) <6B88A30C-0933-3050-A8FD-716B2C03921B> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/DistillerLib.framework/Versions/A/DistillerLib
0x1b75000 - 0x1b77fff +com.adobe.acrobat.acroamt (1.0 - 1.0) <72B45529-8A38-3201-9372-6BF5CABE75F4> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AcroAMT.framework/Versions/A/AcroAMT
0x1b7b000 - 0x1bf1ff3 +com.adobe.AcroPDFProcessor (9.1) <AEDAC410-B7A4-3B34-8C46-923FC84CAB6B> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AcroPDFProcessor.framework/Versions/A/AcroPDFProcessor
0x1c44000 - 0x1c5fff9 +AdobePDFSettings (1) /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x1c79000 - 0x1d86ff7 +com.adobe.PDFPort (AdobePDFPort 2.1.0.21195 - 2.1.0.21195) <8CD89727-70B5-38BC-9DE4-37076BD7238C> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
0x1d94000 - 0x1e01ff7 +libicudata.40.0.dylib (40) <94A53743-16F4-CFA4-164E-D0AC4431B899> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
0x1e04000 - 0x1ea2ff3 +libicucnv.40.0.dylib (40) <24A6FEF6-E3BF-5B0A-702E-FB6C04B8347E> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
0x1ec8000 - 0x21c5ffb +com.adobe.CoolType (AdobeCoolType 5.11.03.1 - 5.11.03.1) <8107CB3B-8C6B-3BA1-BD5F-8ED7DB902209> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x22dc000 - 0x22e9ff3 com.apple.Librarian (1.1 - 1) <68F8F983-5F16-3BA5-BDA7-1A5451CC02BB> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x3700000 - 0x37e5ff7 +com.adobe.amtlib (amtlib 6.2.0.42 - 6.2.0.42) <979ED254-104A-0377-8FC4-E878DA48F523> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/amtlib.framework/amtlib
0x6bbb000 - 0x6bc9fff libSimplifiedChineseConverter.dylib (61) <60899F9C-A79F-3BC2-855E-DC5C78B98FEB> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0xcda9000 - 0xce67ff3 ColorSyncDeprecated.dylib (400) <35E3054C-5DF1-30D4-A368-C4FDB0992373> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x40000000 - 0x400afff7 +com.adobe.JP2K (2.0.0 - 2.0.0.21336) <2A9799C8-5013-372A-ADC5-D456BEA1F6F5> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x8fe04000 - 0x8fe36e57 dyld (210.2.3) <23DBDBB1-1D21-342C-AC2A-0E55F27E6A1F> /usr/lib/dyld
0x90007000 - 0x9003dffb com.apple.DebugSymbols (98 - 98) <9A9ADA0A-E487-3C8F-9998-286EE04C235A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x90040000 - 0x90044ffe libcache.dylib (57) <834FDCA7-FE3B-33CC-A12A-E11E202477EC> /usr/lib/system/libcache.dylib
0x90045000 - 0x9013dff9 libsqlite3.dylib (138.1) <AD7C5914-35F0-37A3-9238-A29D2E26C755> /usr/lib/libsqlite3.dylib
0x9013e000 - 0x90148fff com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <B855E8B4-2EE3-3BFF-8547-98A0F084F9AF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x90149000 - 0x901abfff libc++.1.dylib (65.1) <C0CFF9FF-5D52-3EAE-B921-6AE1DA00A135> /usr/lib/libc++.1.dylib
0x901ac000 - 0x90221ff7 com.apple.ApplicationServices.ATS (332 - 341.1) <BEE998BC-E4A5-3BA0-A6B5-31A1DFA1522C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90222000 - 0x90246fff libJPEG.dylib (851) <2425AE18-C181-3371-922F-4A09C1AC71CD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90247000 - 0x902a1fff com.apple.Symbolication (1.3 - 93) <A839CFC2-F870-3652-B353-15A55D88F88D> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x902a2000 - 0x902cfffe libsystem_m.dylib (3022.6) <9975D9C3-3B71-38E3-AA21-C5C5F9D9C431> /usr/lib/system/libsystem_m.dylib
0x906b1000 - 0x906ddff7 libsystem_info.dylib (406.17) <AA5611DB-A944-3072-B6BE-ACAB08689547> /usr/lib/system/libsystem_info.dylib
0x90c3f000 - 0x90ee2ff3 com.apple.CoreImage (8.4.0 - 1.0.1) <C25B9EEC-4824-3088-BC08-2EA516C0728C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x90ee3000 - 0x90fe1ff7 libFontParser.dylib (84.6) <7D3EB3CC-527E-3A74-816A-59CAFD2260A4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x90fe2000 - 0x90ff5ff9 com.apple.MultitouchSupport.framework (237.4 - 237.4) <59197044-E513-3223-9337-6EB0F828CB82> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x90ff6000 - 0x91002ff8 libbz2.1.0.dylib (29) <7031A4C0-784A-3EAA-93DF-EA1F26CC9264> /usr/lib/libbz2.1.0.dylib
0x91003000 - 0x9103efef libGLImage.dylib (8.10.1) <E29ED217-09B3-3436-A961-B6F8EBAA7BED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x910c0000 - 0x911b1ffc libiconv.2.dylib (34) <B096A9B7-83A6-31B3-8D2F-87D91910BF4C> /usr/lib/libiconv.2.dylib
0x911b2000 - 0x91221ffb com.apple.Heimdal (3.0 - 2.0) <C007CED7-DDC9-3BA1-8077-294FAE9C78D5> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9127e000 - 0x9139affb com.apple.desktopservices (1.7.4 - 1.7.4) <782D711D-7930-324A-9015-686C2F86DBA3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9139b000 - 0x9139dfff com.apple.securityhi (4.0 - 55002) <79E3B880-3AB7-3BF3-9CDF-117A45599545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9139e000 - 0x913a5ff3 com.apple.NetFS (5.0 - 4.0) <1F7041F2-4E97-368C-8F5D-24153D81BBDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x913a6000 - 0x913b2ff7 com.apple.NetAuth (4.0 - 4.0) <4983C4B8-9D95-3C4D-897E-07743326487E> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x913b3000 - 0x913d1ff3 com.apple.openscripting (1.3.6 - 148.3) <F3422C02-5ACB-343A-987B-A2D58EA2F5A8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x913d2000 - 0x913d6fff com.apple.OpenDirectory (10.8 - 151.10) <A1858D81-086F-3BF5-87E3-9B70409FFDF6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x913d7000 - 0x9140aff3 com.apple.GSS (3.0 - 2.0) <EFFA5947-B6BA-3171-B667-9CCB17E0FF2A> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x915ab000 - 0x915d0ffb com.apple.framework.familycontrols (4.1 - 410) <B1755756-BEA2-3205-ADAA-68FCC32E60BD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x915d1000 - 0x915d1ffd libOpenScriptingUtil.dylib (148.3) <87895E27-88E2-3249-8D0E-B17E76FB00C1> /usr/lib/libOpenScriptingUtil.dylib
0x915d2000 - 0x919effff FaceCoreLight (2.4.1) <B12C8721-EFB3-30A2-9A1B-ABCDF5670764> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x91a1c000 - 0x91a76ffb com.apple.AE (645.6 - 645.6) <44556FF7-A869-399A-AEBB-F4E9263D9152> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91a77000 - 0x91addfff com.apple.print.framework.PrintCore (8.3 - 387.2) <0F7665F5-33F0-3661-9BE2-7DD2890E304B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91ade000 - 0x91af7fff com.apple.Kerberos (2.0 - 1) <9BDE8F4D-DBC3-34D1-852C-898D3655A611> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x91af8000 - 0x91afbfff com.apple.help (1.3.2 - 42) <AD7EB1F0-A068-3A2C-9D59-38E59CEC0D96> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91afc000 - 0x91b4aff3 com.apple.SystemConfiguration (1.12.2 - 1.12.2) <15B4EFFC-22D1-3517-BE8C-7947DAA24729> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91b83000 - 0x91bfdff3 com.apple.securityfoundation (6.0 - 55115.4) <8A3DA1FE-1985-3ECB-945A-6B1E853B4BDC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x91bfe000 - 0x91c0dfff libGL.dylib (8.10.1) <74BE67B7-9EA0-3F16-B43B-48CB92C9ED27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x91c11000 - 0x91c96ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <454E950F-291C-3E95-8F35-05CA0AD6B327> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91c97000 - 0x91c98fff libdnsinfo.dylib (453.19) <3B523729-84A8-3D0B-B58C-3FC185060E67> /usr/lib/system/libdnsinfo.dylib
0x91ce1000 - 0x92099ffa libLAPACK.dylib (1073.4) <9A6E5EAD-F2F2-3D5C-B655-2B536DB477F2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9209a000 - 0x920a3fff com.apple.CommerceCore (1.0 - 26.2) <B05709DD-3755-3635-B0CC-6CBBD17CFBD5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x920a4000 - 0x920acfff libcopyfile.dylib (89) <4963541B-0254-371B-B29A-B6806888949B> /usr/lib/system/libcopyfile.dylib
0x920ad000 - 0x92320fff com.apple.RawCamera.bundle (4.07 - 697) <FC3D3781-983B-3262-B3DC-26192A9FA2FD> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x92321000 - 0x9234aff7 libRIP.A.dylib (333.1) <E54E8576-5D00-3FCC-B512-9C42F4093507> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x92352000 - 0x92359fff libsystem_dnssd.dylib (379.38.1) <4F164CA8-4A4F-3B27-B88A-0926E2FEB7D4> /usr/lib/system/libsystem_dnssd.dylib
0x9235a000 - 0x92371fff com.apple.GenerationalStorage (1.1 - 132.3) <DD0AA3DB-376D-37F3-AC5B-17AC9B9E0A63> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x92372000 - 0x92372fff com.apple.Carbon (154 - 155) <C0A26E7B-28F1-3C7E-879E-A3CF3ED5111C> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x923a9000 - 0x923edff7 libGLU.dylib (8.10.1) <5520818E-F290-3942-80B8-370CF9C9B54C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x923ee000 - 0x92485ff7 com.apple.ink.framework (10.8.2 - 150) <A9C3B735-7D5F-3D7D-AA70-2CC852D09CDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x924b7000 - 0x924befff liblaunch.dylib (442.26.2) <310C99F8-0811-314D-9BB9-D0ED6DFA024B> /usr/lib/system/liblaunch.dylib
0x924bf000 - 0x9250eff6 libTIFF.dylib (851) <CC0B94FF-DE56-3CE4-AF93-BCA00C03924B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9255b000 - 0x925a9ffb libFontRegistry.dylib (100) <3B8350C2-4D8F-38C4-A22E-2F855D7E83D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x925aa000 - 0x925ecffb com.apple.RemoteViewServices (2.0 - 80.6) <AE962502-4539-3893-A2EB-9D384652AEAC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x925ed000 - 0x926abff3 com.apple.ColorSync (4.8.0 - 4.8.0) <EFEDCB37-4F20-3CEC-A185-5D2976E11BAC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x929a6000 - 0x929c8fff libc++abi.dylib (26) <3AAA8D55-F5F6-362B-BA3C-CCAF0D3C8E27> /usr/lib/libc++abi.dylib
0x929c9000 - 0x929c9ffd com.apple.audio.units.AudioUnit (1.9.2 - 1.9.2) <CFAAB1B1-DBC7-3FF1-97BA-065C6620360D> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x929ca000 - 0x929d6ffe libkxld.dylib (2050.48.12) <44C8E278-D8CA-3CF4-B3F4-0299654EB341> /usr/lib/system/libkxld.dylib
0x929d7000 - 0x92a2eff7 com.apple.ScalableUserInterface (1.0 - 1) <2B5E454B-BC49-3E85-B54D-1950397C448C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x92a65000 - 0x92a65fff com.apple.CoreServices (57 - 57) <956C6C6D-A5DD-314F-9C57-4A61D41F30CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x92b65000 - 0x92ca0ff7 libBLAS.dylib (1073.4) <FF74A147-05E1-37C4-BC10-7DEB57FE5326> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x92ca1000 - 0x92dae057 libobjc.A.dylib (532.2) <FA455371-7395-3D58-A89B-D1520612D1BC> /usr/lib/libobjc.A.dylib
0x92dbb000 - 0x92dbffff com.apple.CommonPanels (1.2.5 - 94) <6B3E7E53-7708-3DA2-8C50-59C2B4735DE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92e27000 - 0x92e88ff7 com.apple.audio.CoreAudio (4.1.2 - 4.1.2) <C1D471E9-B4D6-3A59-975C-B3B3A25E6058> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x92f27000 - 0x92f37ff2 com.apple.LangAnalysis (1.7.0 - 1.7.0) <875363E7-6D02-3229-A9DD-E5A5568A7D61> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x92f69000 - 0x92fc0ff3 com.apple.HIServices (1.20 - 417) <B8410ABC-E0DB-31EB-B923-17F3B65B5F4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x92fc1000 - 0x93281ff3 com.apple.security (7.0 - 55179.13) <000FD8E9-D070-326A-B386-51314360FD5C> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x93282000 - 0x93282fff libkeymgr.dylib (25) <D5E93F7F-9315-3AD6-92C7-941F7B54C490> /usr/lib/system/libkeymgr.dylib
0x9329d000 - 0x93335fff com.apple.CoreServices.OSServices (557.6 - 557.6) <BE4B0D48-1239-3B9B-9905-551336777F09> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x93338000 - 0x934f4ffd libicucore.A.dylib (491.11.3) <FF55E176-7D66-3DBB-AF86-84744C47A02C> /usr/lib/libicucore.A.dylib
0x934f5000 - 0x9350afff com.apple.ImageCapture (8.0 - 8.0) <B8BD421F-D5A9-3FB4-8E89-AD5CFC0D4030> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x939f0000 - 0x93a21fff com.apple.DictionaryServices (1.2 - 184.4) <A31BB2CE-6965-3610-8B11-EA26EC6D7EEA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x93a22000 - 0x93ad6fff com.apple.coreui (2.0 - 181.1) <C15ABF35-B7F5-34ED-A461-386DAF65D96B> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x93ad7000 - 0x93b3efe7 libvDSP.dylib (380.10) <A9BB03FC-F70B-388F-8917-F8CE69F2164A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x93b3f000 - 0x93b49ffe com.apple.bsd.ServiceManagement (2.0 - 2.0) <9732BA61-D6F6-3644-82DA-FF0D6FEEFC69> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x93b4a000 - 0x93be5fff com.apple.CoreSymbolication (3.0 - 117) <9ECC6770-6FBB-36B3-A4EE-0B60875019A9> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x93be6000 - 0x93c03fff libxpc.dylib (140.43) <C628073D-51A0-3541-A665-1121520508C6> /usr/lib/system/libxpc.dylib
0x93c04000 - 0x93c0dff9 com.apple.CommonAuth (3.0 - 2.0) <B28B58CA-C5B1-378E-A969-6A36C7F754D1> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x93c0e000 - 0x93c0ffff libremovefile.dylib (23.2) <9813B2DB-2374-3AA2-99B6-AA2E9897B249> /usr/lib/system/libremovefile.dylib
0x93c10000 - 0x93c12fff libdyld.dylib (210.2.3) <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
0x93cd9000 - 0x93cf6ff7 libresolv.9.dylib (51) <B9742A2A-DF15-3F6E-8FCE-778A58214B3A> /usr/lib/libresolv.9.dylib
0x93cf7000 - 0x93cf7fff com.apple.Cocoa (6.7 - 19) <354094F0-F36B-36F9-BF5F-FD60590FBEB9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93d09000 - 0x93d0affd libunc.dylib (25) <58599CBF-E262-3CEA-AFE1-35560E0177DC> /usr/lib/system/libunc.dylib
0x93d0b000 - 0x94010ff7 com.apple.CoreServices.CarbonCore (1037.6 - 1037.6) <4DB4B0C9-1377-3062-BE0E-CD3326ACDAF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x947ad000 - 0x947b3fff libGFXShared.dylib (8.10.1) <99622AD6-7A1D-368E-B163-A38400885B45> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9488b000 - 0x9489dff7 libdispatch.dylib (228.23) <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
0x9489e000 - 0x948acff7 libz.1.dylib (43) <245F1B61-2276-3BBB-9891-99934116D833> /usr/lib/libz.1.dylib
0x948b1000 - 0x9495bfff com.apple.LaunchServices (539.9 - 539.9) <C0E0CFFF-3714-3467-87DA-4A6F0AF1953B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9495c000 - 0x94965fff com.apple.DiskArbitration (2.5.2 - 2.5.2) <89822A83-B450-3363-8E9C-9B80CB4450B1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x94966000 - 0x94967fff libsystem_sandbox.dylib (220.3) <C532F6A6-7E85-38F3-8660-EC1066DF67BE> /usr/lib/system/libsystem_sandbox.dylib
0x94968000 - 0x94a25ffb libsystem_c.dylib (825.40.1) <A5C0B70C-5F14-3BF8-AA5B-B22E7B12A4AE> /usr/lib/system/libsystem_c.dylib
0x94a2b000 - 0x94a2bfff libsystem_blocks.dylib (59) <3A743C5D-CFA5-37D8-80A8-B6795A9DB04F> /usr/lib/system/libsystem_blocks.dylib
0x94b5d000 - 0x94b73fff com.apple.CFOpenDirectory (10.8 - 151.10) <3640B988-F915-3E0D-897C-CB04C95BA601> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94b74000 - 0x94c23ff7 com.apple.CoreText (260.0 - 275.17) <433387A6-69C1-32A5-9B61-9E2F6A5F9040> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x94c2f000 - 0x94c31ffd libCVMSPluginSupport.dylib (8.10.1) <F7CD59FE-314A-366E-9A27-CE5BD1D438BB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x94c33000 - 0x94c3affb libunwind.dylib (35.1) <E1E8D8B3-3C78-3AB1-B398-C180DC6DCF05> /usr/lib/system/libunwind.dylib
0x94c3b000 - 0x94c41fff com.apple.print.framework.Print (8.0 - 258) <12AEAD24-6924-3923-9E4A-C5D21231E639> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x94c42000 - 0x94c62ffd com.apple.ChunkingLibrary (2.0 - 133.3) <FA45EAE8-BB10-3AEE-9FDC-C0C3A533FF48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x94c63000 - 0x94cabff5 com.apple.opencl (2.2.19 - 2.2.19) <968DD067-49D0-3B71-A96B-B3579698D992> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x94cf1000 - 0x94cf1fff libSystem.B.dylib (169.3) <F479E729-89C7-3B4C-9731-678EB673A861> /usr/lib/libSystem.B.dylib
0x94cfe000 - 0x94d0cfff com.apple.opengl (1.8.10 - 1.8.10) <385E048A-FFB2-348A-8F80-572C2494A776> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94d0e000 - 0x94d11ff7 com.apple.TCC (1.0 - 1) <437D76CD-6437-3B55-BE2C-A53508858256> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x94d12000 - 0x94d1cfff libsystem_notify.dylib (98.5) <7EEE9475-18F8-3099-B0ED-23A3E528ABE0> /usr/lib/system/libsystem_notify.dylib
0x95d11000 - 0x95d3effb com.apple.CoreServicesInternal (154.3 - 154.3) <A452602B-67CB-39C4-95EB-E59433C65774> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x95d3f000 - 0x95d40fff liblangid.dylib (116) <E13CC8C5-5034-320A-A210-41A2BDE4F846> /usr/lib/liblangid.dylib
0x95d41000 - 0x95d83ff7 libcups.2.dylib (327.7) <6FAC537D-7EC3-3E82-B6E8-F87DE07546B5> /usr/lib/libcups.2.dylib
0x960bd000 - 0x96c79ff3 com.apple.AppKit (6.8 - 1187.40) <94E92235-7AD9-37EF-9B7C-B79074762370> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x96c7a000 - 0x96c84fff libCSync.A.dylib (333.1) <27FD0A7B-AC65-33AB-8F61-3AEF08FC21C3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x96c85000 - 0x96c89ffc libGIF.dylib (851) <4821D945-2E32-3007-8E97-4A69807046FF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x96c8a000 - 0x96c8afff com.apple.ApplicationServices (45 - 45) <677C4ACC-9D12-366F-8A87-B898AC806DD9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x96ccb000 - 0x96cceffc libpam.2.dylib (20) <FCF74195-A99E-3B07-8E49-688D4A6F1E18> /usr/lib/libpam.2.dylib
0x96ccf000 - 0x96cd2ff9 libCGXType.A.dylib (333.1) <FD300AD5-3599-39BE-98AE-2BE8171CC7D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x96cd3000 - 0x96d4fff3 com.apple.Metadata (10.7.0 - 707.12) <D9221655-56FE-332C-82FF-0CA7EDD521C1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x96d50000 - 0x96d51fff libquarantine.dylib (52.1) <094A1501-373E-3397-B632-8F7C5AC8EFD5> /usr/lib/system/libquarantine.dylib
0x96d52000 - 0x96d97ff7 com.apple.NavigationServices (3.7 - 200) <F6531764-6E43-3AF3-ACDD-8A5551EF016A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x96eb1000 - 0x96ebaffd com.apple.audio.SoundManager (4.0 - 4.0) <ABC5FE40-B222-36EB-9905-5C8C4BFD8C87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x96ebd000 - 0x96f21ff3 libstdc++.6.dylib (56) <F8FA490A-8F3C-3645-ABF5-78926CE9C62C> /usr/lib/libstdc++.6.dylib
0x9717c000 - 0x97191fff com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <DE68CEB5-4959-3652-83B8-D2B00D3B932D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x97195000 - 0x971fdff7 com.apple.framework.IOKit (2.0.1 - 755.42.1) <230C6EEC-A926-3720-82DB-25D0FAAEF962> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x971fe000 - 0x971fffff libDiagnosticMessagesClient.dylib (8) <39B3D25A-148A-3936-B800-0D393A00E64F> /usr/lib/libDiagnosticMessagesClient.dylib
0x97200000 - 0x9721affc libsystem_kernel.dylib (2050.48.12) <9B50E922-DCEA-3066-A9B2-613A6D2C5C69> /usr/lib/system/libsystem_kernel.dylib
0x9721b000 - 0x9723ffff com.apple.PerformanceAnalysis (1.16 - 16) <18DE0F9F-1264-394D-AC56-6B2A1771DFBE> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x97287000 - 0x973ffff5 com.apple.QuartzCore (1.8 - 304.3) <F2EFC117-CDC6-3252-A4A8-880965764385> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x97400000 - 0x974a0ff7 com.apple.QD (3.42.1 - 285.1) <BAAC13D2-1312-33C0-A255-FAB1D314C324> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x974a1000 - 0x974b3fff libbsm.0.dylib (32) <DADD385E-FE53-3458-94FB-E316A6345108> /usr/lib/libbsm.0.dylib
0x974b4000 - 0x97897fff com.apple.HIToolbox (2.0 - 626.1) <ECC3F04F-C4B7-35BF-B10E-183B749DAB92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x978d9000 - 0x978ddff7 libmacho.dylib (829) <5280A013-4F74-3F74-BE0C-7F612C49F1DC> /usr/lib/system/libmacho.dylib
0x97b08000 - 0x97b2dff7 com.apple.CoreVideo (1.8 - 99.4) <A26DE896-32E0-3D5E-BA89-02AD23FA96B3> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x97b2e000 - 0x97c0ffff libcrypto.0.9.8.dylib (47.2) <6170B3CB-FA94-3601-A7F7-7F1B953C4F59> /usr/lib/libcrypto.0.9.8.dylib
0x97f89000 - 0x97f94fff libcommonCrypto.dylib (60027) <8EE30FA5-AA8D-3FA6-AB0F-05DA8B0425D9> /usr/lib/system/libcommonCrypto.dylib
0x97f95000 - 0x97f95fff com.apple.vecLib (3.8 - vecLib 3.8) <2D2064EB-FDD5-38AB-B722-4AFA4C6EE0C9> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97f96000 - 0x981adfff com.apple.CoreData (106.1 - 407.7) <EC4B8297-8E01-3778-A8A4-E8747F91109D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x981ae000 - 0x982b9ff7 libJP2.dylib (851) <0D40428F-B7BE-307B-BEDB-256A7FED9804> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x982ba000 - 0x984a2ffb com.apple.CoreFoundation (6.8 - 744.19) <DDD3AA21-5B5F-3D8F-B137-AD95FCA89064> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x984a3000 - 0x985fcffb com.apple.audio.toolbox.AudioToolbox (1.9.2 - 1.9.2) <461C4CCD-5F52-3D2F-AE22-D0CA7EF3F01A> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x989fa000 - 0x98a08ff3 libsystem_network.dylib (77.10) <7FBF5A15-97BA-3721-943E-E77F0C40DBE1> /usr/lib/system/libsystem_network.dylib
0x98a09000 - 0x98a55fff libcorecrypto.dylib (106.2) <20EBADBA-D6D6-36F0-AE80-168E9AF13DB6> /usr/lib/system/libcorecrypto.dylib
0x98a56000 - 0x98a56fff com.apple.Accelerate (1.8 - Accelerate 1.8) <D4F5AB2C-0727-39FD-8EE9-E4DD3D78EB2E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x98a57000 - 0x98a80fff libxslt.1.dylib (11.3) <0DE17DAA-66FF-3195-AADB-347BEB5E2EFA> /usr/lib/libxslt.1.dylib
0x98a85000 - 0x98a88ffc libCoreVMClient.dylib (32.5) <CA150AC5-F98C-3F96-8B11-715B75A89C80> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x98a89000 - 0x98ac8ff7 com.apple.bom (12.0 - 192) <0637E52C-D151-37B3-904F-8656B2FD44DD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x98ac9000 - 0x98ad6ff7 com.apple.AppleFSCompression (49 - 1.0) <166AA1F8-E50A-3533-A3B5-8737C5118CC3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x98ad7000 - 0x98adaff7 libcompiler_rt.dylib (30) <CE5DBDB4-0124-3E2B-9105-989DF98DD108> /usr/lib/system/libcompiler_rt.dylib
0x98adb000 - 0x98b34fff com.apple.QuickLookFramework (4.0 - 555.5) <4E381B7B-7EB5-37FD-9BA7-517DB48D07A7> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x98b76000 - 0x98c4aff3 com.apple.backup.framework (1.4.3 - 1.4.3) <6EA22ED3-BA18-3A37-AE05-5D6FDA3F372F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x98c4b000 - 0x98c4dffb libRadiance.dylib (851) <2739A726-2E9C-38DC-8A6E-412ABDC14405> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x98c4e000 - 0x98ce0ffb libvMisc.dylib (380.10) <D9567F48-ED35-3362-B769-50916D30C601> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x98ce1000 - 0x98ce1fff com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <E54083A7-7467-3C3C-B30F-EE14C8D781A1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x98ce2000 - 0x99002ff3 com.apple.Foundation (6.8 - 945.18) <BDC56A93-45C5-3459-B307-65A1CCE702C5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x99033000 - 0x9911cff7 libxml2.2.dylib (22.3) <015A4FA6-5BB9-3F95-AFB8-B9281E22685B> /usr/lib/libxml2.2.dylib
0x9911d000 - 0x99139fff libPng.dylib (851) <8814CC4D-A472-32CD-8D5C-24F35240F28B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9913a000 - 0x99159ff3 com.apple.Ubiquity (1.2 - 243.15) <E10A2937-D671-3D14-AF8D-BA25E601F458> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x9915a000 - 0x9959cff7 com.apple.CoreGraphics (1.600.0 - 333.1) <76C4858B-AD0A-3165-A65D-64729D6F186C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x99646000 - 0x996aaff7 com.apple.datadetectorscore (4.1 - 269.3) <C11C2014-298E-3E2B-9F5D-02CCD3CA4AB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x99735000 - 0x99743fff libxar.1.dylib (105) <343E4A3B-1D04-34A3-94C2-8C7C9A8F736B> /usr/lib/libxar.1.dylib
0x99fc2000 - 0x9a110ffb com.apple.CFNetwork (596.5 - 596.5) <E2EE5B64-4DFD-3D5E-BB38-9DD0899FFB42> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9a111000 - 0x9a11dffa com.apple.CrashReporterSupport (10.8.3 - 418) <03BC564E-35FE-384E-87D6-6E0C55DF16E3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x9a11e000 - 0x9a22bff3 com.apple.ImageIO.framework (3.2.2 - 851) <36EEBDDC-0619-327E-826F-4413217C9D21> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9a25c000 - 0x9a279fff libCRFSuite.dylib (33) <C9D72D0C-871A-39A2-8AFB-682D11AE7D0D> /usr/lib/libCRFSuite.dylib
0x9a27a000 - 0x9a2d5fff com.apple.htmlrendering (77 - 1.1.4) <5C0C669F-AE07-3983-B38F-EB829B5CE609> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9a2d6000 - 0x9a45fff7 com.apple.vImage (6.0 - 6.0) <1D1F67FE-4F75-3689-BEF6-4A46C8039E70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9a460000 - 0x9a464fff com.apple.IOSurface (86.0.4 - 86.0.4) <6431ACB6-561B-314F-9A2A-FAC1578FCC86> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9a468000 - 0x9a469ffd com.apple.TrustEvaluationAgent (2.0 - 23) <E42347C0-2D3C-36A4-9200-757FFA61B388> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9a46a000 - 0x9a4acfff libauto.dylib (185.4) <3098A75E-438E-3F18-BAAC-CD8F1CC7C2F7> /usr/lib/libauto.dylib
0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Acrobat XI Pro/Acrobat Distiller.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xba900000 - 0xba91cffd libJapaneseConverter.dylib (61) <A3F2F55D-E491-3532-A8F6-8D3F2455704F> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21ffc libKoreanConverter.dylib (61) <39F6BEE7-AE54-3423-B920-2A3573BC9A1A> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 2 | |
thread_create: 0 | |
thread_set_state: 0 |
Calls made by this process:
task_for_pid: 0 | |
Calls made by all processes on this machine:
task_for_pid: 930 | |
thread_create: 2 | |
VM Region Summary:
ReadOnly portion of Libraries: Total=152.9M resident=108.5M(71%) swapped_out_or_unallocated=44.4M(29%)
Writable regions: Total=147.3M written=4508K(3%) resident=8332K(6%) swapped_out=0K(0%) unallocated=139.2M(94%)
REGION TYPE | VIRTUAL | |
ATS (font support) | 31.9M | |
ATS (font support) (reserved) | 4K | reserved VM address space (unallocated) |
CG backing stores | 476K | |
CG image | 4K | |
CG shared images | 1216K | |
CoreServices | 1456K | |
MALLOC | 82.8M | |
MALLOC guard page | 48K | |
Memory tag=242 | 12K | |
Memory tag=243 | 4K | |
Memory tag=35 | 6992K | |
Stack | 70.1M | |
VM_ALLOCATE | 16.1M | |
__DATA | 7088K | |
__DATA/__OBJC | 212K | |
__IMAGE | 528K | |
__IMPORT | 8K | |
__LINKEDIT | 36.9M | |
__OBJC | 1548K | |
__OBJC/__DATA | 104K | |
__PAGEZERO | 4K | |
__TEXT | 116.0M | |
__UNICODE | 544K | |
mapped file | 115.3M | |
shared memory | 2356K | |
TOTAL | 491.2M | |
TOTAL, minus reserved VM space | 491.2M |
Model: iMac12,2, BootROM IM121.0047.B1F, 4 processors, Intel Core i7, 3.4 GHz, 16 GB, SMC 1.72f1
Graphics: AMD Radeon HD 6970M, AMD Radeon HD 6970M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334348302D4348392020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353237334348302D4348392020
Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1333 MHz, 0x0D9B, 0x000000000000000000000000000000000000
Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1333 MHz, 0x0D9B, 0x000000000000000000000000000000000000
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.72.0-P2P
Bluetooth: Version 4.1.7f4 12974, 3 service, 21 devices, 3 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: WDC WD1001FALS-403AA0, 1 TB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 3
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 2
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa130000 / 5
USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfa132000 / 9
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 7
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
This looks like a problem reading a font. Unfortunately, no indication which one, but it would probably be an otf font.
Thanks for your reply, however I deleted EVERY OTF font and use the same set of system fonts that all others in my office and still have the same problem.
I take that back. I searched for fonts by using my finder and deleted them and I was finally able to open and use Distiller!!! THANK YOU!!!
